Old 06-11-2006, 03:17 PM   #1
zenki-217
zenki-217's Avatar
zenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nice
Some one please SHOOT me NOW!!!!
This fucking sucks .. I got all my parts for my car Saturday. 10 hours later all installed.. Last but not least the hareness that I have been so nervous over.. Crank Crank Crank no starty.. Ecu light on the entire time.. I think at that time I had spark I had fuel from the pump but sounded weird... Hella pressure in the fuel line..But no fuel in the cylinders. Took the harness out and went home... Looked it over compared to the crappy on line diagram .. Every thang seemed right so I went back to the shop in the morning.. Nothing no spark no fuel pump no ecu lights just cranks...wtf
zenki-217 is offline   Reply With Quote
Old 06-11-2006, 03:22 PM   #2
WhittSr20det
WhittSr20det's Avatar
WhittSr20det is an unknown quantity at this point
sure it isnt your ecu ..... maybe it got fried try swapin a ka pc in there... 2 see if the light comes on on it ...
Sr20DetBlacktop
ACT stage 2..6 Puck Clutch
Front mount
Custom Hard Piping
GREDDY TYPE R.. No knockoff shit here
Super AFC
Auto Meter: BoostGuage,Water Temp,Oil Pressure
Megan Racing Dump Pipe
Megan Racing Down Pipe
Megan Racing Full Exhaust
Lsd
Falken Torque 5 Wheels
Front And Rear Suspension:
Kyb gr2 Struts
Cusco Camber Plats
Tein 2 Inch lowering Springs
Cusco Front and Rear Strut Bars
Blitz TwinSBC Boost Controller
WhittSr20det is offline   Reply With Quote
Old 06-11-2006, 03:28 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
How do you know if you had spark and fuel?
The FSM has procedures to check if your injectors are spraying properly.
SR? KA? RB? CA?
Old 06-11-2006, 03:33 PM   #4
zenki-217
zenki-217's Avatar
its a sr ..I know the fuel pump was kicking on... And the fuel line when removed was under a extreme amount of pressure and shoot across my garage..Does the light always come on on the sr ecu while trying to start it in perfect running condtion?
Old 06-11-2006, 04:07 PM   #5
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
my light was on in my swap... open ur ecu up look to see if anythings toast and test your coilpacks
sepulchral is offline   Reply With Quote
Old 06-11-2006, 05:14 PM   #6
zenki-217
zenki-217's Avatar
coilpacks are not getting any juice ..
Old 06-11-2006, 11:01 PM   #7
NemeGuero
No more nissan.
NemeGuero's Avatar
Who wired it up for you?
Old 06-12-2006, 01:01 AM   #8
bardabe
bardabe's Avatar
come to thik maby u hooke dthe fuel line in backwards. alot of ppl seem to do that on SR swaps. it is pretty easy to get the lines mixed up. the firs time arround. fromt he fuel shooting out across the garage it sure sounds liek it
Review Thread
bardabe is offline   Reply With Quote
Old 06-12-2006, 01:26 AM   #9
impulze240sx
impulze240sx is making his/her stupidity well-knownimpulze240sx is making his/her stupidity well-knownimpulze240sx is making his/her stupidity well-knownimpulze240sx is making his/her stupidity well-known
Send a message via AIM to impulze240sx
i cant kill you but this will do the trick
impulze240sx is offline   Reply With Quote
Old 06-12-2006, 05:14 PM   #10
zenki-217
zenki-217's Avatar
http://camel-towing.com/docs/S13%20S...into%20S14.htm
I went by this to wire the engine up.And I think I know the prob now.. My tired ass pu the fuel line on backwards..And now I think the harness got damaged when pulling it in and out.
Old 06-12-2006, 06:21 PM   #11
smithers584
smithers584 is an unknown quantity at this point
check to make sure that you connected the harness where the coilpacks connect to it. i know it sounds dumb, but after hours of working its easy to overlook that. if not, start from your ecu and shoot the wires the the ignitor. there are four of them.
smithers584 is offline   Reply With Quote
Old 06-12-2006, 06:47 PM   #12
tchenku
tchenku is making a name for him/her selftchenku is making a name for him/her selftchenku is making a name for him/her self
Send a message via AIM to tchenku
the coil pack harness also has a ground wire that's bolted to the back of the engine. make sure that that's connected. it's also easy to overlook this lil ground wire. don't ask how i know this. ;P
tchenku is offline   Reply With Quote
Old 06-12-2006, 07:54 PM   #13
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Check your fuses and test the injector harnesses with a noid light. This will start your way on solving the problem with the cylinders not getting fuel. If there is not light when cranking, look into a possible wiring problem for one.
Coilpacks not getting power? Willing to bet a wiring problem, but use the old multimeter to test the coilpacks. The chances of all 4 being bad are pretty slim. The procedures are outlined in the FSM. If there is still a problem, check the ignitor.
If the coil packs need to be replaced, look into some splitfires...
zero.counter is offline   Reply With Quote
