Old 06-11-2006, 05:55 PM   #1
gotta240
taking apart motor....what do i mark!?
Ok, im rebuilding my toyota 22r(i know this is a nissan forum, but all these steps are the same, and this site ownes others).
I'm about to dissasemble the short-block. What do i need to mark? The MAIN CAPS, are already marked 1-4. Do i also need to mark the connecting rod caps, and also mark which way they sat on the crank? Everything will be honed and/or bored and new bearing will be used..
Old 06-11-2006, 06:34 PM   #2
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
Yes, you need to mark the connecting rod caps.
You sould mark or make note of anything you may not be able to remember how it was assembled.
The best thing for you to do would go buy or download a FSM since you'll need to know torque values and tolerances when you go to reassemble the engine.
sncs14 is offline   Reply With Quote
Old 06-11-2006, 06:38 PM   #3
gotta240
thanks...also...is the main pulley bolt(goes to crank) reverse thread, or normal? I'm 99percent sure its reversed...but theres 1 percent thats pissin me off!
thanks
Old 06-11-2006, 06:57 PM   #4
sncs14
sncs14's Avatar
I think it's normal but you would really be better off just getting the shop manual/FSM just to be sure.
Old 06-11-2006, 07:04 PM   #5
gotta240
ok..thanks a lot....
Yes, i deff. need to get a fsm... I'm just tearing this apart tonight so i can get it to a machine shop to hot-tank, magnaflux, and machine it. I'll grab a manual before re-assembling...
Old 06-11-2006, 07:21 PM   #6
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
mark the rods, the caps... the bearings if ur checkin for size... dont damage the crank.....!!!!!
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-11-2006, 09:46 PM   #7
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
be sure to mark them in a directional manner. pay attention to the rod cap "tangs" to make sure that they go on in the same manner but a #4 main cap can't go on 180 off so it's important to not only mark where they came from but in what direction they were facing.
TheWolf is offline   Reply With Quote
Old 06-12-2006, 12:43 AM   #8
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
the book you have to get is "How to keep your Toyota Alive" it has been so helpful on my 20r. but i'd mark everything and once you think you've marked everything mark some more. it never hurts to be over cautious, especially in your engine.
drifter808 is offline   Reply With Quote
Old 06-12-2006, 12:47 AM   #9
seanc
seanc is an unknown quantity at this point
let me know if you need any help i have rebuilt/built several of those engines from for the street to for this:
seanc is offline   Reply With Quote
Old 06-12-2006, 12:51 AM   #10
drifter808
^^nice. gotta love outer roll cages.
Old 06-12-2006, 09:02 AM   #11
gotta240
SEANC- yes!!! I do need help!!!
I'm building this motor for work and for REAL LONG(3k miles in MEXICO!) Road trips where a running truck is a MUST!! For long term reliability, and a little extra performance( in know the two are opposites) what pistons, bearings, and cams would you recomend? What do you think of Keith Black Pistons?
I'm on a thousand dollar budget for machine work and parts, but i'm re-assembling myself..thanks a LOT!!!
