Old 06-13-2006, 11:57 AM   #1
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
just installed stances coilovers...
i just installed stances on my car and for some reason the rear isnt as stiff as the front for some reason... i adjusted the height to a ba lil higher then the front so my exhaust wont scrape. but now it feels as if its not nearly as stiff as the front when i push down on the back of the car. im not sure if its maybe that i possibly blown the shocks or not. let me know if this is normal thanks.
SilviaSR20DET is offline   Reply With Quote
Old 06-13-2006, 12:01 PM   #2
k2fender
k2fender is an unknown quantity at this point
Thats normal. Theres a lot less weight in the back.
k2fender is offline   Reply With Quote
Old 06-13-2006, 12:27 PM   #3
Bryants95240sx
Bryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the rough
Well the spring rates are going to be stiffer for the front than the rear b.c of the engine being in the front. But you could have more preload on the springs in the front than the rear, you want the front to be stiffer though if you want the car to handle right. So check the preload and your settings other than that its probable pretty normal.
Bryants95240sx is offline   Reply With Quote
Old 06-13-2006, 12:57 PM   #4
Realchaos1
Realchaos1 is a well-known jackass
Send a message via MSN to Realchaos1
Hey I'm from WA too! Yeah, mine are like that too. The weight was my immediate assumption.
btw clean s14 bryants^
Realchaos1 is offline   Reply With Quote
Old 06-13-2006, 01:16 PM   #5
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
All coilovers are gonna be like that. The force needed to compress the spring in front is 8kg/mm and rear is 6kg/mm. Thats a 2kg difference.
1kg=2.2 lbs, so 2*(2.2)= 4.4 lbs of force each mm (difference btwn front and rear). Quite a bit.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 06-14-2006, 12:17 AM   #6
driftskeetka24e
driftskeetka24e's Avatar
driftskeetka24e is an unknown quantity at this point
Send a message via AIM to driftskeetka24e
can u not adjust the dampening on the shocks? if so just adjust them to be stiffer if u want stiffer
and w00t for washingtonions come out to evergreen speedway in monroe june 23rd for a drift event 50 bucks to drive lots of seat time last one ppl got around 20 runs
driftskeetka24e is offline   Reply With Quote
Old 06-14-2006, 11:44 AM   #7
SilviaSR20DET
oh ok thanks guys, um just curious i wasnt sure if i did the adjusting on the front right... but when i lower the car i used the two collars witht the spring seated cause i couldnt turn the bottom perch anymore so i can lower it.... am i doing this wrong? In other words, can someone tell me how to adjust height correctly. thanks
