Old 06-22-2006, 06:46 PM   #1
Yahnozha
Yahnozha is an unknown quantity at this point
Power Steering Project
I think this is my first post here, anyway, im knee deep with my S13 project. A 90 with KA24DE in there. Well the bottom end was shot, thrown rod, cracked block, but the head was undamaged. I picked up a KAE for hella cheap and im in the process of putting the DE head on the E block. No small task i tell you.
Anyway, one of the major setbacks has been the power steering. The E block has no bosses on it for the DE PS pump bracket, and no room on the head for the E PS pump bracket. Since this is gonna be a dediacted track car, ive removed the AC and making a bracket to put the DE PS pump there.
To tidy things up a bit, ive decided to go with teflon lines SS braid hose with crimp on -6an fittings. The lines are the easy part, along with switching to an aftermarket frame rail cooler with -6an ends, i needed -6an ports on the PS pump and the steering rack to run the trick lines.
Well here you go, and its not a bolt in solution, some modifications needed to be made to the rack housing where the lines come in/out of it.
PS Pump fitting
Another shot
Steering Rack fittings
Just to warn you, the PS system operates around 1200 psi, so you need adequate hose to do this, the teflon/ss braid style has 2500-3000 capacity so it should be more than enough.
Pretty cool eh?
Yahnozha is offline   Reply With Quote
Old 08-21-2006, 06:13 PM   #2
CarloSR
CarloSR is making a name for him/her selfCarloSR is making a name for him/her selfCarloSR is making a name for him/her self
Nice one P@t.
CarloSR is offline   Reply With Quote
Old 08-21-2006, 06:33 PM   #3
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
That's pretty pimp. I'm not a KA guy so I didn't know that the DE head would match the E block. No mods needed?
Old 08-21-2006, 06:52 PM   #4
McRussellPants
whats the pitch/thread on those AN adapters?
I've been thinking about doing it for a while since my HP hose is busted.
McRussellPants is offline   Reply With Quote
Old 08-21-2006, 07:16 PM   #5
Ninjabread
Ninjabread's Avatar
"No small task i tell you"
lol, and sounds like you have a cool project going man... keep up the hard work!
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 08-21-2006, 07:56 PM   #6
TheTimanator
TheTimanator's Avatar
yeah, would you mind sharing that info? for the pump and rack (i need it for the rack) I've been wanting to get my power steering up and running for a long time and if I could do it myself I might actually get it done!
Old 09-15-2006, 11:17 AM   #7
Yahnozha
HAH, didnt know you were on here Carlos
Yeah, the head bolts up but a LOT of additional work is needed, looking back I wouldnt suggest this swap to anyone.
Youll have to machine the PS rack housing flat, I used an oring style -6an on one port (custom tool to do this) and the other was a standard fitting, dont remeber the pitch off the top of my head...the PS pump fitting is the same too...ill look it up later, the fittings are about $10-$15 each.
Old 09-15-2006, 11:41 AM   #8
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
care to be more specific? what's the benefit? perhaps a write up?
It'd be easier to hunt down and rebuld a DE no?
