Old 06-22-2006, 11:16 PM   #1
Nissangtrpower
Nissangtrpower's Avatar
Nissangtrpower is an unknown quantity at this point
Need Help On My S14 Sr20det Jdm Front Clip
hi i just brought my s14 jdm front clip but it doesn't has a cluster on there so is there are any way i can tell how many miles it has on the car? and how can i tell if this s14 sr20det front clip is from the 95-96 early model or from the late 97-98 model? can i tell by checking the computer ,dash board ,transmisson or the engine?
Nissangtrpower is offline   Reply With Quote
Old 06-22-2006, 11:20 PM   #2
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
Run The VIN# on the firewall??
sillyvia13 is offline   Reply With Quote
Old 06-23-2006, 12:52 AM   #3
Nissangtrpower
hi you meant the metal plate in the engine bay or on the dash board?
Old 06-23-2006, 12:54 AM   #4
CaoBoY
CaoBoY is making a name for him/her selfCaoBoY is making a name for him/her self
it doesnt have a vin, not one that you can trace...because its not a united states car.
pulling outta the game:
http://www.zilvia.net/f/showthread.p...wpost&t=119867
parting out, just let me know.
CaoBoY is offline   Reply With Quote
Old 06-23-2006, 01:08 AM   #5
Dousan_PG
Dousan_PG's Avatar
97/98 is usually able to tell by:
if its 'ribbed' on the front cover (below valve cover): 97/98
if the ECU is "WC" its zenki
if its "NA" its kouki
those are probably the easiest and quickest ways to tell
as far as mileage goes. your SOL on that. just hope its relatively low
the 35k mileage thing people claim motors have its BS
Aaron
Pink GodziRa
Old 06-23-2006, 01:19 AM   #6
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
http://www.courtesyparts.com/specs/vin.html
Jung918 is offline   Reply With Quote
Old 06-23-2006, 01:28 AM   #7
Nissangtrpower
so what are the different betwee the zenki and kouki ? and are there any way i can find out what year the front clip is from? thankyou
Old 06-23-2006, 01:30 AM   #8
Dousan_PG
Dousan_PG's Avatar
difference? turbo could differ
but really nothing but wiring
nothing for the most part that woul affect powre or anything. its basically the same motor.
u could ready my post to findthe differences
read posts before posting the same question.
Aaron
Pink GodziRa
Old 06-23-2006, 01:34 AM   #9
Nissangtrpower
thankyou but what i really want to find out is what year the front clip is from?
Old 06-23-2006, 01:37 AM   #10
Dousan_PG
Dousan_PG's Avatar
did you read ANY of the fucking above posts?
becusae 2 of them tell you EXACTLY how to find out the year it is from
get a brain.
Aaron
Pink GodziRa
Old 06-23-2006, 01:54 AM   #11
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
dousan is dead on. Those are the two ways two tell. The earlier model zenki had the same s13 maf plug type. And the kouki had the hump plug used on most 96-98 Nissans. It really does'nt matter, they are both the same engines.
sblack13 is offline   Reply With Quote
Old 06-23-2006, 02:19 AM   #12
Nissangtrpower
i see , because i have bought a s14 front clip before and the engine wasn't that good and it was from a 95-96 model because it still has the fenders on the clip so i can tell,and i just want to be more caution this time before getting it, because i haven't pick up the clip yet. also is 3380$ a good prices for the front clip? how can i tell if the engine is in good condition? what compression ratio it should has? thanks for any help.
