Old 06-25-2006, 06:04 PM   #1
staygold24
staygold24's Avatar
staygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enough
Need Help Now!
My car is having the wierdest problem. I was just eating and my car was parked. Then I came back to it and it wouldnt start. My girlfriend was sitting in the car and the cd player spit out a cd. Then I walked around the car and it started up only now the clock said that it was 1:07.. and it was around 7:45. Then I drove home and parked it in my garage and tried it again.. it wouldnt start. I took out the cd in it and it still wouldnt start. I have no idea what could be wrong. Please help if you know what it is.
staygold24 is offline   Reply With Quote
Old 06-25-2006, 06:09 PM   #2
methos237
methos237 is an unknown quantity at this point
Start simple, check all the electrical connection and make sure they're tight (battery, ignition coil, etc.) I only say this because I almost spent $50 and replaced my MSD coil, only to find out that the nuts holding the wires on the post weren't tight.
Also, be a little more specific... when you turn the key, does it just click or actually acts like it doesn't want to turn over. Could be the difference between an electrical problem and a fuel / air problem.
methos237 is offline   Reply With Quote
Old 06-25-2006, 06:11 PM   #3
staygold24
staygold24's Avatar
I forgot to mention the engine is a redtop sr.
Old 06-25-2006, 07:03 PM   #4
staygold24
staygold24's Avatar
also clicks when i turn the key sorry. I also know that it has a boost leak but the issues with the clock and cd player make it strange.
Old 06-25-2006, 07:11 PM   #5
methos237
problem sounds to me like it's your battery or battery cables, especially with the clock resetting. Check your cables and check your ground. If the connects are tight, try taking a wore brush to the connections and cleaning all the oxidation off of them, and then reconnect and try.
Old 06-25-2006, 11:01 PM   #6
staygold24
staygold24's Avatar
Ok thank you. They are pretty oxidized but even when the car just has the key in the ignition the safcII says that my volts are around 11.9. Im also only running a mower battery.
Old 06-26-2006, 06:52 AM   #7
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
It should still be over 12v's. Clear and tighten your batt connections and check your charging sysyem. With the car running you should get 12v's+/13v's at the batt.
NIK90s13 is offline   Reply With Quote
Old 06-26-2006, 10:09 AM   #8
staygold24
staygold24's Avatar
any more ideas guys? could this be something major?
Old 06-26-2006, 10:55 AM   #9
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
I had a weird problem a while ago. Car would start fine but wouldn't re-start with a warm engine. Turned out to be the CTS plug was a little bit loose. No problems with guages though.
Like already mentioned, check your connections and fuses.
Old 06-26-2006, 02:23 PM   #10
staygold24
staygold24's Avatar
I think I found it. it was a bad connection to the battery. I cleaned off the terminals and noticed that a grounding to the battery looked chewed up. I think thats it cause i moved the battery.. and then it worked. and right after i cleaned the connections it worked. but while i was driving on the causeway i hit some bumps and my gauges went crazy so i think thats the problem.
Old 06-26-2006, 06:56 PM   #11
NIK90s13
NIK90s13's Avatar
After you get the post and grounds cleaned and tight, make sure your alt. is charging.
Old 06-27-2006, 09:59 PM   #12
staygold24
staygold24's Avatar
how would i make sure?
Old 06-28-2006, 06:21 AM   #13
NIK90s13
NIK90s13's Avatar
Get a volt meeter, they, you can get a cheap one, they arent that expensive, and any parts store or walmart will have them. You should get 13v+ at the alt, the same at the batt with the car running.
Old 06-28-2006, 10:39 AM   #14
staygold24
staygold24's Avatar
oh ok ill just use my safcII
