Old 06-27-2006, 07:44 AM   #1
Stillslow
Stillslow is an unknown quantity at this point
Removing S14 Sr head??
I have to remove the head off an S14 engine I have but I need to know the pattern for the head bolts.They do have to be taken off in a sertan order so you dont warp the head dont they??I dont want ot just start taking the bolts out and end up warping the head.
Stillslow is offline   Reply With Quote
Old 06-27-2006, 07:50 AM   #2
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
I don't think you should touch that shit if you have to come here to ask.
Leave it to a real mechanic.
Start in the middle.. and detorque. EZ. It's pretty touch, hope you can handle it.
95zilvia is offline   Reply With Quote
Old 06-27-2006, 10:25 AM   #3
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
Download the S15 FSM and read it, then decide if you're up to it. Here's the link for the manual http://www.zeroyon.com/index/content/view/24/47/
WilloW is offline   Reply With Quote
Old 06-27-2006, 03:24 PM   #4
Stillslow
I can handle it its not a big deal but every motor is diffrent and I want to know the right order before I do it.
Old 06-27-2006, 08:55 PM   #5
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
when you pull the head it is a good Idea to check the head anyway. It would suck big time to reinstall it and blow the headgasket because it was a little out.
+1 on downloading the FSM.
NIK90s13 is offline   Reply With Quote
Old 06-28-2006, 01:51 AM   #6
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
Its not an easy task to remove the head. Expect 2 days with all the tools in the world.
If its like the KA_E you will have to unbolt the support for the intake, and let the intake sit against the fender, then un-bolt everything else. MARK YOUR VACCUM HOSES BEFORE REMOVAL
IMPORTANT stuff a piece of wood or something inbetween the timing chain so it doesnt drop down inside the block...otherwise you'll have to spend all that time figuring it out afterward. Same with the cams. Don't turn the cams unless you really really need to.
Also look into replacing all gaskets, intake, exhaust, as well as the head. May as well while you are in there.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 06-28-2006, 04:29 AM   #7
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
there's a thing to keep the chain from dropping btw. Not sure what you mean by turning the cams. the cam sproket and shafts gets removed when you remove the head. The nuts to the head studs are under the rockers basiclly.
driftingisgay.com
nrg is offline   Reply With Quote
Old 06-28-2006, 05:21 AM   #8
95zilvia
They come stock not with head studs, but with head bolts.
Yes you have to take out the cams.
Old 06-28-2006, 10:01 AM   #9
Stillslow
I am not reusing anything on the motor that the head is coming off of I am just pulling the head to sell it.The motor is blown and is already sitting on the floor all apart.So all I am looking for is the order that the bolts are toqued so that I can take them off in the opposite order.
Old 06-28-2006, 10:21 AM   #10
Stillslow
Thanks man thats the exact info I was looking for.
Thats a really good link best thing I have ever downloaded very detailed info.
Old 06-28-2006, 11:04 AM   #11
WilloW
WilloW's Avatar
You're welcome. Just pass that info along to other people.
Old 06-28-2006, 03:14 PM   #12
Stillslow
already been done.
Only took me a few minutes to get everything apart all I need now is to get those head bolts out there some tight going to need an air gun I think.
Old 06-28-2006, 09:45 PM   #13
spegt
spegt is not welcome here anymorespegt is not welcome here anymorespegt is not welcome here anymorespegt is not welcome here anymorespegt is not welcome here anymorespegt is not welcome here anymorespegt is not welcome here anymorespegt is not welcome here anymorespegt is not welcome here anymorespegt is not welcome here anymorespegt is not welcome here anymore
Just get a breaker(sissy bar) I always do it by hand. Crack every one first, then go through and lossen them the rest of the way.
Oh yea and never never ever ever start on the inside(whoever said that needs shot) Always outside in always.......ALWAYS!!!!
spegt is offline   Reply With Quote
Old 06-28-2006, 11:30 PM   #14
S13Eye
S13Eye's Avatar
S13Eye will become famous soon enoughS13Eye will become famous soon enoughS13Eye will become famous soon enough
Send a message via AIM to S13Eye
Breaker bar and a pipe on that. I use a section of pipe from my service jack. The idea is to turn the fastener smoothly. If you have a short breaker bar, the bolts will vibrate as they loosen - this will cause the bolt torque to violently fluctuate. It takes less energy to keep an object in motion, than to place it in motion. If you use an air gun on a head bolt, you shouldn't be allowed to use safety scissors, much less get anywhere near a car.
This isn't overkill, and you would be surprised at how easy it is to damage a head.
S13Eye is offline   Reply With Quote
Old 06-29-2006, 07:18 AM   #15
Stillslow
Ya thats what I have been told.
