Old 06-17-2002, 06:47 AM   #1
sil80
sil80 is an unknown quantity at this point
How do I know if my car has ABS? I looked around for like a "ABS" badge but didnt see one. Can you tell by just looking at the calipers or master cylinder?
My car is a 91 240 SE.
Five degrees of separation - from you and your license
91 240sx SE
sil80 is offline   Reply With Quote
Old 06-17-2002, 09:12 AM   #2
Zexel
Zexel is an unknown quantity at this point
1.  Read the owners manual
2.  Hit a good 30 mph and slam on your brakes as hard as you can...then you'll know for a fact!
All throttle, no bottle.[br]Drive it like you stole it.
Zexel is offline   Reply With Quote
Old 06-17-2002, 09:44 AM   #3
sil80
Zexel, usually when someone does not know the answer to a question they keep there mouth shut. In the future please avoid my threads cause I dont have time to deal with 16 year olds with nothing beater to do then show there lack of Intelligence.
OOO BTW here is the answer that gives just a tad bit more detail then yours.. ooo wait I mean it completly answers my questions unlink your jibberish.
To determine if it had ABS, look for an ABS warning light in the gauge cluster. Or pop the hood and follow the lines from the master cylinder. If it has ABS, there will be an ABS valve box on the passenger side of the engine bay near the firewall.To determine if it had ABS, look for an ABS warning light in the gauge cluster. Or pop the hood and follow the lines from the master cylinder. If it has ABS, there will be an ABS valve box on the passenger side of the engine bay near the firewall.
91 240sx SE
Old 06-17-2002, 01:28 PM   #4
2fortysex
2fortysex is an unknown quantity at this point
So you cant tell if you have ABS by looking at your calliper or the master cylinder?...  I remember hearing something about this... something about looking for a small mechanism on the calliper...
2fortysex is offline   Reply With Quote
Old 06-17-2002, 02:19 PM   #5
sil80
I dont know --- anyone know?
Anyone know where the ABS light is suppose to be on the s13 gauge cluester. I think its suppose to be to the left of the wiper fluid light but dont know since there I dont have the light/label..... might be why I dont have ABS.
91 240sx SE
Old 06-17-2002, 02:47 PM   #6
HKrpS13
HKrpS13 is an unknown quantity at this point
Send a message via AIM to HKrpS13
Pop the hood open and look at the top left (pasenger side) corner. If you have ABS, there should be something thats silver/ chrome. Thats the ABS system.
On the gauge, it should say ABS right next to the check engine lamp (or some where on that side).
(I'm not sure about this one) Brake caliper should have a wire for the rear and front, I haven't looked at it yet.
HKrpS13 is offline   Reply With Quote
Old 06-17-2002, 05:56 PM   #7
gh6o6
gh6o6 is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sil80 @ June 16 2002,12:44)</td></tr><tr><td id="QUOTE">Zexel, usually when someone does not know the answer to a question they keep there mouth shut. In the future please avoid my threads cause I dont have time to deal with 16 year olds with nothing beater to do then show there lack of Intelligence.
To determine if it had ABS, look for an ABS warning light in the gauge cluster. Or pop the hood and follow the lines from the master cylinder. If it has ABS, there will be an ABS valve box on the passenger side of the engine bay near the firewall.To determine if it had ABS, look for an ABS warning light in the gauge cluster. Or pop the hood and follow the lines from the master cylinder. If it has ABS, there will be an ABS valve box on the passenger side of the engine bay near the firewall.</td></tr></table><span id='postcolor'>
im confused did you answer your own question or did i miss something?
gh6o6 is offline   Reply With Quote
Old 06-17-2002, 09:02 PM   #8
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
If you don't know if you have it then you don't have it <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'> &nbsp; I also have a '91 S13 and it's painfully obvious that I have ABS
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
Old 06-18-2002, 12:18 AM   #9
HKrpS13
same with above. 91' LE
Old 06-18-2002, 11:33 AM   #10
sil80
nrcooled - why are you wasting my time and possibly others that might have the same question? Your reply provided nothing for this thread...... unless you can provide something positive to the threads I create please avoid them. Thanks
gh6o6 - actually asad answered my question a little after I created this thread.
91 240sx SE
Old 06-18-2002, 12:32 PM   #11
HKrpS13
If you have ABS, on the gauge it should say "ANTILOCK" next to the cruise control lamp.
Old 06-18-2002, 01:19 PM   #12
rampid360
rampid360 is an unknown quantity at this point
Send a message via ICQ to rampid360
You should be able to tell by following the brake lines under the hood near the firewall. If they run to a little box on the passenger side, then you have abs. If there is no little box, then you dont. Also, check to see if you have an ABS fuse. Im not sure about s13's..but when you start the car on s14's a light comes on that says ABS or ANTILOCK or something of that nature
Edit: &nbsp;oops...i guess i should read the rest of your second post before answering.....oh well...at least I gave you a correct answer <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
For every winner there are dozens of losers. &nbsp;Odds are you're one of them.
rampid360 is offline   Reply With Quote
Old 06-18-2002, 02:21 PM   #13
sil80
Just like to say thanks to all those that helped and answered my question. Odd that that I dont have ABS when I know other 91 SEs do though.... ::weep:: ::weep::
91 240sx SE
Old 06-18-2002, 06:15 PM   #14
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
*warning - useless post ahead*
Sil80 - it may be in your best interests NOT to tell people to avoid your posts. &nbsp;At least they answered. &nbsp;Especially intelligent people that have a good bit MORE experience than yourself with the 240..(nrcooled) &nbsp;You may need their knowledge one day.. &nbsp;and you also make yourself out to be a dick.
Have a nice day &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
sykikchimp is offline   Reply With Quote
Old 06-18-2002, 06:29 PM   #15
HKrpS13
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sil80 @ June 18 2002,1:21)</td></tr><tr><td id="QUOTE">Odd that that I dont have ABS when I know other 91 SEs do though.... ::weep:: ::weep::</td></tr></table><span id='postcolor'>
Not all SE has ABS.
Old 06-19-2002, 08:47 AM   #16
jdkruger4
jdkruger4 is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ June 17 2002,8:15)</td></tr><tr><td id="QUOTE">*warning - useless post ahead*
Sil80 - it may be in your best interests NOT to tell people to avoid your posts. At least they answered. Especially intelligent people that have a good bit MORE experience than yourself with the 240..(nrcooled) You may need their knowledge one day.. and you also make yourself out to be a dick.
Have a nice day <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
you stole the words right out of my mouth <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
stock '91 240sx, black, LE w/ 90k miles, and high performance spoiler rust that was poorly &quot;fixed&quot;
jdkruger4 is offline   Reply With Quote
Old 06-19-2002, 10:23 AM   #17
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
When you turn the key to the accessories possition, you should see a light that says either ABS or antilock on the left hand side of the instriment pannel. It has been a while since I have seen it, my old roomates se has ABS. Neither of mine do.
But unless it burned out you can't miss it.
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Lurker Supreme!
www.midatlantic240sx.com
  • 91 Coupe
  • 97 KA24DE+T SOLD
uuninja is offline   Reply With Quote
Old 06-19-2002, 01:36 PM   #18
sil80
sykikchimp & jdkruger4,
Let me ask you a couple questions? Was nrcooled post educational to this thread? Was it even funny?
This is the tech section not chat and like most people I posted it in hear in hope to get an accurate answer and avoid all the stupid comments.
Everybody always talks about how they dig this forum so much more then FA cause it feels more like a community.... well its comments like nrcooled and you sticking up for him that make me disagree...
There are people here that answered my questions with out being ass's about it and rather informational so I guess I dont care if nrcooled thinks im a dick cause he was being one in the first place. Sound childish? Yep but really dont care.
Again thanks to all that actually took the time to answer my question...
91 240sx SE
Old 06-19-2002, 03:52 PM   #19
DSC
New Title
DSC is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sil80 @ June 18 2002,4:36)</td></tr><tr><td id="QUOTE">sykikchimp & jdkruger4,
Again thanks to all that actually took the time to answer my question...</td></tr></table><span id='postcolor'>
nrcooled did not help you, that is obvious...what he was doing was showing his dislike for ABS. &nbsp;It did not hurt you in any way...if you don't like comments like that, just skip over them.
"Everybody always talks about how they dig this forum so much more then FA cause it feels more like a community...."
It is people like you on FA that make it feel like less of a community.
"I dont care if nrcooled thinks im a dick cause he was being one in the first place."
He did nothing wrong. &nbsp;Get your head out of your ass! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/hmmm.gif" border="0" valign="absmiddle" alt=':hmmm:'>
"Sound childish?"
yes
"Yep but really dont care."
If you are asking us for help, you had better fucking care.
Someone with an SR > Someone who doesn't even know if they have ABS and is being disrespectful
DSC is offline   Reply With Quote
Old 06-19-2002, 07:03 PM   #20
tnord
tnord's Avatar
tnord is an unknown quantity at this point
if you don't know if you have ABS or not, chances are you aren't somebody that uses it.
also.....nrcooled.........why would you not want abs? (i really hope the answer has nothing to do with "drifting")
tnord is offline   Reply With Quote
Old 06-20-2002, 01:49 AM   #21
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
Most SE's do not have ABS. And I think nrcooled's post was informative, and he wasn't trying to joke arround.
DuffMan is offline   Reply With Quote
Old 06-20-2002, 09:52 AM   #22
thich
thich is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">also.....nrcooled.........why would you not want abs? (i really hope the answer has nothing to do with "drifting")</td></tr></table><span id='postcolor'>
go out to a solo2/autocross event and you will see why ABS sucks.
iirc, what ABS technically does is brake until the point where your brakes lock and then releases it before it locks then brakes it again, and goes through the same sequence until your vehicle has slowed down.
I've been to a few autoX events and have seen how cars with ABS and cars w/o ABS performed when it came to stopping or slowing down.
5.0 Mustangs and corvettes usually seem to fair well when it came to stopping b/c their wheels just lock and stop them dead on as compared to some of the imports at the autoX.
I don't know if this is the same reason nrcooled hates ABS or not, but this is my reason I hate it.
former Zilvia username: kitoro
thich is offline   Reply With Quote
Old 06-20-2002, 10:14 AM   #23
DSC
New Title
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (thich @ June 19 2002,12:52)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">also.....nrcooled.........why would you not want abs? (i really hope the answer has nothing to do with "drifting")</td></tr></table><span id='postcolor'>
I don't know if this is the same reason nrcooled hates ABS or not, but this is my reason I hate it.</td></tr></table><span id='postcolor'>
If your wheels lock up you can't stop nearly as fast as if they weren't locked up. &nbsp;So if your not good enough to do threshold brakeing, you NEED ABS or you will lockup and go off course or atleast lose time. &nbsp;I plan to disable mine after a couple events (or runs even in one day) to see what the difference is like. &nbsp;Our ABS also seems to come on prematurely.
Old 06-20-2002, 10:48 AM   #24
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
abs pros - it threshold brakes like you wish you could
abs cons - it is sometimes premature and doesn't get to the actual threshold as well as you could; weight; something else to break
thich - have you ever noticed how vettes and moosetangs run GIANT, sticky tires at autoxes? &nbsp;Those help. &nbsp;The little smoke puffs mean they weren't quick enough to modulate (which abs always is).
(hope I don't get bitched at for posting in the hijacked portion of the thread)
HippoSleek is offline   Reply With Quote
