![]() Join Date: Jun 2006
Help with steering wheel wiring!!
Hey guys i need some help with wiring up my MOMO Mod 21 steering wheel, and my hub is HKB Boss Kit, my issue is wiring up the turn signal. Ive searched through this forum, and also have importnut as a favorite.
When i tugged the steering wheel off the white harness part got ripped (in the pic below) ![]() i spliced 3 of the 5 wires however, but not the 2 wires that went to the air bag module since i wont need it right. ![]() ![]() basically im stuck, i do not know how to re-wire up the turn signal, also at this point my ignition will not turn, only thing the works is head lights, high beam, dome interior light. Please help me out, i know this is a easy mod, i dont usually ask for help, but in this case, i do. Thanks. |
![]() Join Date: Dec 2002
The turn signal doesn't 'wire up', it's mechanical. The blue ring in the center of the column is the cancel switch, you have to drill the hub to seat against it correctly. Nothing else needs to be done unless you're keeping cruise.
And good job breaking the spiral cable, that's a $940 part that you could have sold. |
#6 |
You popped a large fuse somewhere, but I have no idea how. Steering wheel removal doesn't require messing with any wiring besides the spiral cable, and it's all ignition powered. The horn is a ground trigger at the column.
Go under the hood with a meter and get started. |
