Old 07-07-2006, 12:45 AM   #1
94cc0rd
94cc0rd's Avatar
clutch problem not resolved completely
For the past couple months my clutch has been weird... there is a lot of end play ... about half the length of the clutch travel, there is no pressure. I did a search on here and asked some friends and they all said to change the clutch master cylinder. I took it to a shop and changed out the master and slave cylinder today and it didn't seem to change much. There is slightly more pressure, after the half way point, but until then, it's the same.. no pressure.
Does this have to do with my clutch or flywheel or anything? I plan on getting a new clutch, either oem or aftermarket, but I was expecting the master cylinder to fix the problem. The mechanic told me that the master cylinder was infact leaking.
Another bit of info on the problem, after long drives, or during really hot weather, the clutch did get worse. When kept in a cool garage or under shade, it wouldn't be as bad.
94cc0rd is offline   Reply With Quote
Old 07-07-2006, 06:47 AM   #2
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
As far as the clutch getting worse after you drive, it sounds like the clutch is going, or you have oil leaking on to the clutch.
If you are sure the master and slave are bled properly, than you need to check the ajustment at the pedal.
NIK90s13 is offline   Reply With Quote
