![]() Join Date: Mar 2006
cylinder #3 not firing
turn car on and the idle is terrible, i started taking out plugs one at a time...
1 - take off and car wants to die so i put back in 2 - take off and car wants to die so i put back in 3 - take off and nothing changes... hmm 4 - take off and car wants to die so i put back in so obviouslly #3 is messed up.... i switched plug #3 with #2 and it was the same as stated abovem i switched the plug wire #3 with #2 and it was still the same as above, i bought a new distrubutor cap installed it and STILL the same as above, is #3 not getting a spark or whats going on?? thx in advance |
Check the plugwires and and injector coils with a DVM. See if it's coming from there. Check the Sparkplug. Do a compression test. I've come across this problem with a friend's truck once, turns out there's a bad compression in one of the cylinders. Intake valves were fucked. Replaced valves, and problem was solved.
#5 |
![]() Join Date: Feb 2005
i got a few. where are you located?
pulling outta the game: http://www.zilvia.net/f/showthread.p...wpost&t=119867 parting out, just let me know. |
