Old 07-10-2006, 07:58 PM   #1
thrasher
thrasher is an unknown quantity at this point
power steering question
my steering pump just went on my 1990 s13 silvia ca18det, does anyone know wat pump will replace it. i've heard that an 88 pulsar might but i want to know for sure. if anyone can answer this that would be awsome!
thrasher is offline   Reply With Quote
Old 07-10-2006, 08:07 PM   #2
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
WELCOME AND SEARCH!!!!! Next time look around before you post, we have a FAQ for every engine. It took 3 minutes for me to find this. How are you going to re-imburst me? j/k *a
Originally Posted by sLiDewAys
*(Credit goes to http://www.ca18det.org )*
If you are looking for parts, tell the autoparts store that you have an 88' Nissan Pulsar NX SE. It will be the correct part 99% of the time!
Oxygen Sensor CA18ET 200sx Bosch 13276 $47.99
Spark Plugs CA18ET* 200sx NGK PFR6A-11 $Varies
PCV Valve CA18DE Pulsar NX Bosch PCV142 $2.99
Thermostat CA18DE Pulsar NX 491-180 $4.99
Thermo Gasket CA18DE Pulsar NX Felpro 35228 $0.89
Water Pump** CA18DE Pulsar NX B150-1350 $33.99
Upper Rad. Hose KA24DE 240SX L-564 $7.99
Lower Rad. Hose KA24DE 240SX M-563 $7.39
Oil Filter CA18DE Pulsar NX Bosch 3400 $5.49
Alt Belt 4pk855 $9.99
PS Belt 4pk845 $8.99
AC Belt 4pk840 $8.99
* Exhaust side needed
** Includes Gasket
Other Spark Plug Options:
PFR6/BCPR6's for standard (gap of 1.1mm)
PFR7/BCPR7's for lightly modded (gap of 0.8-10mm - see what works for you)
BCR8's for high boost applications. (gap 0.6-0.8 dependant on boost level)
Oil filter 15208-H8911 Ryco Z386 or Ryco Z145A
Door bump rubbers 01658-J7000 (Skyline R31)
Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces
Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head
Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner
Intake manifold gasket 14035-53J10 (SR20 all)
Turbo inlet flange gasket 14415-75F10 (200SX)
or 14415-17M00 (S13 all) The Aust 200SX one fits.
Turbo outlet flange gasket 14445-26E00 (S13 all)
Engine front oil seal 13042-42L00 (CA18 all)
Engine rear oil seal 12279-18V00 (CA18 all)
Oil pan seal front 11121-01F10 (CA18 all)
Oil pan seal rear 11121-01F15 (CA18 all)
Head gasket 11044-51E00 (CA18 all)
Head gasket 11044-50F00 (SR20) until 9/92
Head gasket 11044-50F01 (SR20) from 9/92 till 7/93
Head gasket 11044-50F10 (SR20) from7/93 onwards
Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits
Engine gasket kit 10101-56E25 (CA18DET)
Engine gasket kit 10101-50E25 (SR20DET)
Engine gasket kit 10101-51E26 (SR20D)
Flywheel Bolts 12315-55M00 $2.18
Valve grind gasket kit 11042-51E25 (CA18 all)
Valve grind gasket kit 11042-50F25 (SR20 all)
Fan belt 11720-V7301 (CA18 all) L = 855mm
Fan belt 11720-52F00 (SR20 all)
Compressor belt 11920-V7301 (CA18 all) also suits power steering pump
Compressor belt 11920-30R10 (SR20 all) also suits power steering pump
Water pump 21010-V5528 (CA18) until 8/90
Water pump 21010-V5529 (CA18) from 8/90
Water pump 21010-52F00 (SR20 all)
Thermostat 21200-V0201 (CA18 all) 82.0 C
Thermostat 21200-V0206 (CA18 all) 88.0 C
Thermostat 21200-53J00 (SR20 all)
Radiator cap 21430-01F01
Radiator hose - upper 21501-35F10 (CA18 all)
Radiator hose - lower 21503-35F00 (CA18 all)
Radiator hose - upper 21501-52F00 (SR20 all)
Radiator hose - lower 21503-52F00 (SR20 all)
Bonnet bump rubbers (large) 62840-D0100 (Skyline R31)
Engine coolant 10120-89904 Castrol
Dash switch back lights Nissan Aust, have similar types
$11.00 each **** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each
Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ).
Wheel nut 62840-21001 (R31 Skyline)
Brake pads See service info page. Bendix and others.
heater hose w/valve part 02-0036 or p/n ch1649 same as 1988/90 holden commodore 3.8ltr
(needs to be cut slightly)
Headlight globe Who cares Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam.
Rear Dampers
( shockers ) See Nissan Dealer or Nismo KONI. Part no. 80-401-081 sports kyb.
Approx $315 a pair.
Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 or Z201
Air Filter 16546-V0100 (same as R31 Skyline) K&N high flow reusable type P/N 33-2031-1
Spark plugs 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm)
Spark plugs 22401-53J16 (PRF6B, SR20DET)
Crank angle sensor 23731-85M10 (CA18 all)
Crank angle sensor 23731-50F01 (SR20 all)
Coolant temp sensor 25080-89903 (S13 all)
Steering Rack Boot (LHS) 48203-10V25 (same as local 300ZX, mabey R32 also)
Oil pressure sender unit 25210 89920 (generic nissan??)
Oil pressure sender 25240-89920 (S13 all)
Cam shaft timing belt 13028-51E25
Cam belt idler bearing 30BD219DWAX
Cam belt tenioner bearing. 35BD219DWAX
Clutch Master Cylinder rebuild kit. PBR Aust. K8690 (contains pistons).
K7689X (rubber components only).
Clutch Slave Cylinder 3062069F03
S13 Main Handbook (English) Nissan Publication SM9E-OS13G0 $230 tax ex.
RS13 Service Manual, Main Issue (Japanese) Nissan A008009 $143 Tax Ex
SR20DET S13 Engine supplement Nissan A008011 $187 Tax Ex
SR20DET S13 Wiring supplement Nissan A108012
crank sprocket - 13021-D4200 - $29.26
woodruff key - 00926-51900 - $1.02
crankshaft plate (behind sprocket) - 13022-42L00 - $1.78
Turbo Manifold gaskets -> head:
14036-D4201 (x2)
14036-D4202 (x2)
KA24 and CA18 use the same radiators (Unlike the SR) with both ports on the USDM passenger side
www.raretrick.com seems to carry quite a few CA products, including SAMCO CA18DET upper and lower radiator hoses as well as turbo hoses.
'90RPS13 is offline   Reply With Quote
Old 07-10-2006, 08:21 PM   #3
thrasher
i hate to be a jerk but i already looked through that and i dont see a power steering pump in there anywhere
Old 07-10-2006, 08:33 PM   #4
MegasquirtCA
MegasquirtCA's Avatar
MegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfection
unfortunatly your out of luck, it has to be replaced with another CA18DET pump.
MegasquirtCA is offline   Reply With Quote
Old 07-10-2006, 08:33 PM   #5
blu808
blu808's Avatar
Flying rat says "Use a ca18 power steering pump"
Old 07-10-2006, 08:55 PM   #6
thrasher
oh that sucks, wat about a sp resivoir? do i have to get an orginal or can that be replaced by another part?
Old 07-10-2006, 09:47 PM   #7
blu808
blu808's Avatar
What
Old 07-10-2006, 10:10 PM   #8
MegasquirtCA
you can use a KA24DE p/s reservoir.
Old 07-10-2006, 10:41 PM   #9
'90RPS13
'90RPS13's Avatar
ROFL, Flying rat FTW! *a
Old 07-11-2006, 01:02 AM   #10
thrasher
thanks megasquirt
Old 07-11-2006, 02:50 AM   #11
blu808
blu808's Avatar
Indeed. You cannot defeat the flying advice rat.
Old 07-16-2006, 03:33 PM   #12
xiong
xiong is an unknown quantity at this point
91 power steering pump
I was wondering if someone has a 91 to 93 power steering pump for my conversion?
xiong is offline   Reply With Quote
Old 07-17-2006, 10:23 AM   #13
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
They're bountiful in junkyards. Happy huntings.
