Old 07-27-2006, 04:15 PM   #1
aggiez32
aggiez32 is an unknown quantity at this point
For Redtop SR: JWT ECU, Dist, coil, and plug wire setup for 89-90
Called JWT to confirm that this is legit. I purchased a car with a blown head gasket and have been parting some things out. It was running a KA24E ECU upgraded by JWT to run a coil and distributor setup. Ben at JWT has confirmed the programming and validitity (I hadn't heard of it) of the system and said that it has the same performance and HP capabilities as the stock SR setup. It is setup for an SR MAF and SR injectors. You use KA24E wiring on the SR and everything should be peachy.
Included is:
JWT ECU - Turbo, Manual, Federal for SR 370cc injectors, SR MAF
Distributor, KA24E coil, plug wires, KA24E wiring harness, and plugs.
If anyone else has any more info they would like to share, please be my guest.
Asking $250 shipped for the setup. This is for a Redtop.
Brady
91 Aztec Red 300ZXTT Stage III+ (RIP)
90 Black S13 FB - Awaitng a rebirth
aggiez32 is offline   Reply With Quote
Old 09-18-2006, 04:45 PM   #2
twofourzerosx
twofourzerosx can only hope to improve
so this is a distributor setup for a sr20det? pics please
twofourzerosx is offline   Reply With Quote
