Old 08-04-2006, 08:31 PM   #1
tubedae86
tubedae86 is an unknown quantity at this point
Diff questions
I am an avid car guy but i have a lack of knowledge on Nissan diffs. Recently in a phone conversation with Doug from Fairlady Motors (Up Garage USA) I made myself look like an ass with that lack of knowledge... Anyways, can someone help me out on the
different types
which is better
more expensive
model changes
jdm to usdm
6 bolt
Opinions please
etc....
Anything would be great.
Thanks, Matt
tubedae86 is offline   Reply With Quote
Old 08-04-2006, 08:34 PM   #2
Dousan_PG
Dousan_PG's Avatar
search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode search mode
Aaron
Pink GodziRa
Old 08-04-2006, 08:57 PM   #3
tubedae86
I searched... but nothing as specific as I would like... I would also like opinions from you guys. I am speaking specifically S13, not really worried about any other models. I am getting a S13 rear subframe and making it fit into my Corolla.. From that I am making a jig and reproducing tubular rearend as a direct placement, with full heim joint suspension. This will also not be a daily driver by any means.Thanks
Old 08-04-2006, 09:03 PM   #4
kandyflip445
kandyflip445's Avatar
LOL, you did say anything.
Clutch type- Uses clutch plates and is typically more harsh than a HLSD or VLSD. They come in 1.5 and 2 way usually. 1.5 has full lockup characteristics under acceleration and about half under deceleration. A 2way locks up both ways. This is with the gear engaged/not in neutral. If it is in neutral then the LSD won't lock up. People like these for drifting and a lot are willing to use them for the street also.
HLSD uses gears to transmit torque to the outer wheel. There is a good writeup on www.howstuffworks.com Typically people like these for autox/daily drivers/road racing. They don't have any wearing parts per say. So it should last the longest out of the LSDs.
VLSD is a viscous unit. It uses a fluid that thickens when it heats up due to the two wheels spinning at different rates. When this fluid thickens then the wheels start to become locked together. These typically are the easiest to ruin if you drive hard. Most people will go with something else just because there is no gurantee that you are going to find a working unit.
Anything else just search. There is much more but those are some basics.
My 240 vBgarage
Old 08-04-2006, 09:14 PM   #5
tubedae86
Thank you.
Now this car is not going to be a daily, and I plan on getting a 2 way lsd anyways. My question is toward the fact that you can only use vlsd diffs with vlsd axles. 6 bolt are clutch type right?
Also, you cant just order one aftermarket differential and get rid of the vlsd for a 2 way. Or can you get one aftermarket 2 way to replace them all and are interchangable?
Old 08-04-2006, 09:20 PM   #6
kandyflip445
Best way to know for sure what you are getting is call the company you are ordering from. They will tell you which output shafts are needed for the particular diff. SEARCH!!!!!
My 240 vBgarage
Old 08-05-2006, 12:58 AM   #7
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
If you are just chaning out the interenals then all you really have to worry about is if it is for open or the viscous diff as the output shafts are different lengths.
Jung918 is offline   Reply With Quote
Old 08-05-2006, 01:10 AM   #8
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
With that said, welded diff.
60bucks, and done. Stock housing, axles, the whole shibang.
And its not DD, so you don't have to worry about tire squealing.
And its always locked, so you don't have to worry about it unlocking.
AND its easy on the pocket, with minimal maintenance.
DD Welded for meee!!
SochBAT is offline   Reply With Quote
Old 08-05-2006, 01:24 AM   #9
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
^ +1 for daily driven welded.
Weld it! It's cheap, and perfect if you are planning on drifting. As long as you get it done from the right guy it will last. Right now I got Flyberts SPL weld going on almost a year of daily driving/drifting.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 08-05-2006, 01:26 AM   #10
SochBAT
Same here. Lockin like it was just installed.
Its fun to have.
Old 08-05-2006, 02:43 AM   #11
buku_points
buku_points's Avatar
buku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfection
yea get a welded,i just got one it love it.
buku_points is offline   Reply With Quote
Old 08-05-2006, 04:31 AM   #12
SwiftS14
SwiftS14 is an unknown quantity at this point
yay for Flyberts SPL welded diff, best investment in my car, mall parking lots are not so fun but drifting with a welded diff is a blast, no more disapointing lock up from a vlsd.
SwiftS14 is offline   Reply With Quote
Old 08-05-2006, 06:10 AM   #13
SochBAT
glad you joined the Darkside guy.
Told you! its better than anythin out there.
Old 08-05-2006, 11:10 AM   #14
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
weld loc'd FTW!!! Support the zilvia fam
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 08-10-2006, 09:52 PM   #15
240DriftKid
240DriftKid's Avatar
240DriftKid is an unknown quantity at this point
Send a message via AIM to 240DriftKid
hey i have a viscous with the sr20 axles can i get that welded im in the 909 so cal area does anyone know any shops or somewhere i can get mine welded? thanx!
240DriftKid is offline   Reply With Quote
Old 08-10-2006, 10:47 PM   #16
kandyflip445
You don't weld a viscous. You'd need to get an open diff.
My 240 vBgarage
Old 08-11-2006, 05:37 PM   #17
240DriftKid
aww man that sux i just got it put in too!! where do i get a open diff with the sr20 hubs? ya kno the 5 bolt.
