Old 08-04-2006, 09:27 PM   #1
Xandy Boosts
Xandy Boosts's Avatar
Xandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfection
Send a message via AIM to Xandy Boosts
Overheat, thermostat removed completely, new radiator, etc HELP
Okay after getting a new radiator, it kept overheating, so I removed the thermostat completely because it kept overheating with a new one anyways. New water pump was installed. I seached all the threads and did everything everyone said which is: raise car, start car, turn heater on full blast, bleed coolant etc etc.
Strange thing is, the car would drive fine for a week, then last night it started overheating again. I was at work so i lifted the car, tried to bleed a little more but only coolant came out, so I closed everything back up and it drove fine!
Today I go and drive to work and it drives fine, no overheating (I work 30 minutes away) but as soon as I started the park, the car shaked/vibrated a lot. Not small vibrations more like big shakes kind of. The temp was fine and everything, I open up hood and check the radiator, the left side of the radiator was hot, but the right side of it was cool, very cool. I drive back home then halfway, it starts overheating and it was hell trying to get home.
Now I have no idea what's wrong with it. When it started overheating, I turned heater to hot at full blast and hot air DID NOT come out. I'm all out of idea's, if you guys tell me to bleed, I'll bleed it more but I did it last night for 30 minutes and nothing but coolant came out. I had 6 gallons of premixed coolant on hand that's why I made sure.
Do you guys think the water pump is out again? Nothing is leaking from it though so I'm not sure what to think. Can't be a thermostat problem since it's gone. Any help would be greatly appreciated.
Xandy Boosts is offline   Reply With Quote
