Old 08-05-2006, 02:53 PM   #1
alpalwal1
alpalwal1 is an unknown quantity at this point
No oil to head for a bit after startup... am i screwed?
started the motor up for the first time (ka-t) and then shut it off after about 30 seconds when i realized there was no oil pressure.
once i figured out my oil pressure problem i started it up again and the head clacks a lot.
i pulled the valve cover and my cam caps.... the cams, caps, and journals (below the caps) have scoring from lack of oil.
what should I do? this is bad, but is this at least what was clacking?
do I have to pull my head or should i just get new cams and caps?
Help!!
alpalwal1 is offline   Reply With Quote
Old 08-05-2006, 03:22 PM   #2
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Did u check to see if you have any oil first? maybe your oil pan was leaking over night or while you were doing the built. Can also be oil pump, just check to see if you have oil or any leaks. Good luck
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 08-05-2006, 10:13 PM   #3
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
um.. if you had no oil pressure, make sure your timing chain tensioners didnt seize first off.. then, dont go pulling your head, check the clearances in the cam journals or whatever i cant think right now.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 08-06-2006, 06:04 PM   #4
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
30 seconds should not do MAJOR damage. Are you sure you did not run it for longer? Or were you running it at a higher RPM? It had been a long time since ive pulled a valve cover off of a KA (I've been an SR guy for over a year now).. but if you have hydraulic lifters, you are more than likely clicking from a lack of oil pressure to the lifters. Something I would be more concerned about is the internals. If your oil pump was cavitating enough to score your cams, then your rod and main bearings can do the same. =/
daryl337 is offline   Reply With Quote
Old 08-06-2006, 06:14 PM   #5
alpalwal1
Car just doesn't run well
My car is finally running, but poorly. It's a built KA-t with msd 50lb injectors and a safc
first off my boost gauge only says 10" of vac at idle and it should be at 20. I tried the boost leak tester and i didn't find anything. What else could lead to low vacuum?
second, when you try to rev the engine up at all it just dies. i've gotten it up to like 1.5k with like 2% throttle, but any more and it dies.
the safc was all set up for my old sohc ka with 450's. besides leaning the injectors out a bit, is there anything else I should have changed between sohc and dohc?
Old 08-06-2006, 07:13 PM   #6
NemeGuero
No more nissan.
NemeGuero's Avatar
replace oil pump...
