![]() Sup felllow zilvians, I just recieved my wheels they are 17x7 +42 all around. I wanted to know what size tires i should get? I was thinking of 225/45-17 for the fronts, but as for the rear I am not too sure, i want a little more meat in the rear; I was thinking of 245 or 255/40-17, but would that fit? and also I have tein super street dampers.
Thanks for everyone's suggestions. |
#2 | |
![]() Join Date: Feb 2005
#8 |
so get some 50mm space and longer studs? what size studs?
Do you know where i can get them for a pretty good price? Do I really need spacers because they are a bit pricey? what would happen if I don't get it? Thanks. Last edited by KodSil80; 08-09-2006 at 01:56 PM.. |
#9 | |
![]() Join Date: Nov 2004
![]() You bought Honda rims, congrats. :ghey: |
#10 | |
#11 | |
#13 | ||
![]() Join Date: Jan 2006
![]() lmao @ squidd
ho ha ho chi chi |
#14 |
LMAO!!
Will those even fit without hitting everything inside the fender?!?!
![]() KILL!KILL!KILL!KILL!KILL!KILL!KILL!KILL! |
#17 | |
as if now they fit fine, and eventually i'll get spacers, sell the ff wheels, and get 00/00/00 tires, but in the mean time it's a learning process for me so flame on as usual, and thanks for all the comments. |
#18 | |
![]() Join Date: Aug 2005
THEY FIT FINE LOL I ALMOST FELL OUT OF MY CHAIR HEARING THAT SHIT. HOW COULD THEY FIT FINE YOU SAID YOU HAD COILOVERS EVRYONE KNOWS THAT A +42 OFFSET WILL NOT CLEAR THEM YOUR SMOKING SOME GOOD SHIT |
#20 |
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Here's the tire size you should run:
000/00/00 Instead of buying tires, sell your wheels. Run on stockers. Eat ramen for a month (or hot pockets like me). Then get something the proper size that can fit real rubber, clear coilovers, and clear brakes. Something that isn't higher offset than stock might help. |
#21 |
wut option sed...ff spec wheels are worse than stockers.
and besides, you really want spacers in there that are larger than a bigmac? thats low rider 13" pizza cutter on a cadillac deville style.
-John 93 240SX FOR SALE!!!!! |
#22 |
Whoa, with sizes like that the back sides of your wheels might actually touch each other!
Shoulda done some research to make sure they would fit, but you should be able to sell them pretty quick if you don't get spacers. |
#23 |
First off stock rims are 16x6 +40
With 17x7 +42 rims Clearance on the inside of the rim (the portion of the rim we don't see) is 15mm less than stock The position of the rim is going to be extended 11mm closer to the fender. Second, unless you want to run over fenders or roll and pull the fenders forget about the need for 50mm spacers. Test fit the rims on the car and then figure out what needs to be done. (IE. Roll the fenders, buy spacers, etc) Oh...yeah...if you were to buy the suggested 50mm spacers the spacers would make the rim off set as if it were -8 which would give you 35mm of clearance on the inside of the rim and also extend the rim 61mm further outward than the stock rims. You may need spacers end the end so keep that in mind. Third the size tire you use will depend on what you want, need, or like. Test fit with used tires before you put money into buying new tires. |
#27 |
I'm not sure which is more idiotic, thinking that 17x7 +42 "looks fine" or thinking that a 255 will fit on it.
if it's a learning process you need to learn how to fuckin learn: search and read all the wheel threads we've beaten to death here google for "wheel offset" and learn about wheel sizing google your tire manufacturer and see what size wheel they recommend for a specific tire size google how to kill urself and get to work oh yeah, here: ![]() Fugly. Nice rivets For similar money u could get some used FN's in better sizes |
#29 |
After reading through this thread I can't believe people are this goddamn stupid.
First off I ran a 7" wide rim with +26 offset and at full counter the shit was rubbing against the brakeline bracket, cut a nice slice in the tire. So if I were you I'd carry a spare at all times. Second, how the fuck can you even THINK of running such a wide tire on a skinny ass rim. Its gonna look like a fucking offroad jeep wrangler and handle even worse. Take one turn and the whole tire is gonna fold under the sidewall. Third you'd seriously need a 40mm spacer on those things. Which is not only dangerous cause you won't have enough threads to hold your shitty rim on but its just stupid anyways. Finally get pics...I'd love to see what "looks fine" means to someone like yourself.
#30 |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
I think he ment they fit fine when he test fitted them on his car.
He was obviously looking at his car from the side, not the front or the rear. Dude, you need to search HARD, before you buy anything and try to ask questions about it on Zilvia. The widest tire you should be going on those wack wheels is a 215/40/17. You SHOULD sell them though, and get some wheels with an offset lower than 20. FYI, NO one likes high offsets here. Ask questions when you get some real parts for your car.
![]() Best way to do business with me? Make your best offer FIRST. |
