Old 08-10-2006, 09:14 AM   #1
nikech1
nikech1 is an unknown quantity at this point
need help with power door locks on s14
i just put in a 1996 door on my 1995 240sx in order to fix the window problem and to avoid the hassle of taking out the tracks and regulator and install it on the previous door. now the power door locks are not working. is there anyway to modify it or make it work? i have already searched the thread.
nikech1 is offline   Reply With Quote
Old 08-10-2006, 01:10 PM   #2
g6civcx
g6civcx's Avatar
Stupid question, but did your power door lock work before you swapped doors?
Old 08-10-2006, 04:20 PM   #3
projectRDM
projectRDM's Avatar
Wiring for the door locks is the same, however it's possible that the new door doesn't have the OE security (optional in 96) so you won't have alarm functions. Otherwise the door lock motor is the same, sounds like you just have a bad actuator in the new door.
And swapping a door to avoid swapping the internals is twice as much work. You could have done all the internals parts in 10 minutes and not needed to mess with realigning the door.
Old 08-10-2006, 07:11 PM   #4
nikech1
yes is it did work before i swapped doors
Old 08-10-2006, 07:37 PM   #5
nikech1
what would it be easier to remove and install, power door locks or power window regulator? and how? if you know by chance.
Old 08-10-2006, 07:43 PM   #6
projectRDM
projectRDM's Avatar
Both are simple to remove. How? Download an FSM.
I can gut an entire door is less than five minutes, that's including wiring harness, latch, belt moulding, and glass. Shouldn't take anyone else more than fifteen the first time.
Old 08-10-2006, 08:28 PM   #7
nikech1
i looked at the fsm i cant seem to find a diagram of how to take either of them out
