Old 08-16-2006, 04:25 PM   #1
S13Disco
S13Disco is making a name for him/her selfS13Disco is making a name for him/her self
Send a message via AIM to S13Disco
SR S13RedTop T3/T4
well i have an S13 Red Top i just installed my new setup.
I have...
Air research T3/T4 Turbo
XSPOWER EXHAUST MANIFOLD
38MM EXTERNAL WASTEGATE
Z32 MAF
Z32 FUEL FILTER
VENOM 550 INJECTORS
WALBRO 255 FUEL PUMP
S-AFC II
MEGAN FPR
BEFORE I PUT EVERYTHING IN MY STOCK SR RAN PERFECT NOW IT DOESNT REALLY WANT TO START. IT WALL START AFTER CRANCKING FOR A WHILE AND THEN DIES LIKE IN 5SEC. DOES ANYONE KNOE WHAT MY PROBLEM COULD BE?
S13Disco is offline   Reply With Quote
Old 08-16-2006, 04:33 PM   #2
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
do you have the SAFC set so it will accept the Z32 mafs? if not its 6 in 2 out or the other way around. i forget.
drifter808 is offline   Reply With Quote
Old 08-17-2006, 01:58 AM   #3
bardabe
bardabe's Avatar
make sure the FPR is hooked up to the return line not the feed line other wise it wont have enough Fuel that is what happened to my Friend when he was installing the HKS fuel rail he bought.
Review Thread
bardabe is offline   Reply With Quote
Old 08-20-2006, 03:07 PM   #4
S13Disco
The FPR is on the correct side. and yes i have the SAFC to that. Anyone else?
Old 08-20-2006, 03:35 PM   #5
g6civcx
g6civcx's Avatar
Easy things first. Check MAFS wiring. Check fuel pump for proper operation. Check for vacuum leak. Then check MAFS signal and fuel pressure.
