Old 09-03-2006, 09:47 AM   #1
Gutling
Gutling is an unknown quantity at this point
MPH Calculator
Hi, was wanting a little help with something. I have tried searching, but not knowing exactly what to search for has brought up a lot of offtopic/useless information.
I am trying to figure out mph based on rpm/tiresize/rearend/gearratios
I found a bunch of calculators on the internet, but I do not know what values to input.
I have a 89 240sx, open diff, with a sr20det redtop 5speed
my wheels are 245/45/18
I am wanting to do this to see if my speedo is off any and curiosity at what the car does after 110mph
Sorry if this is the third one of these today or anything, but I have been trying to search and appreciate any help!
Gutling is offline   Reply With Quote
Old 09-03-2006, 09:57 AM   #2
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
Go on a dyno. Numbers on paper are always rounded. The more rounded numbers you use, the less accurate your result will be. Things like tirewear could contribute to a slight speed inaccuracy (may or may not, just an example). To know what it actually is, get it physically tested on a dyno.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 09-03-2006, 10:05 AM   #3
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
the rear end is 4.083, use google to find the SR gear ratios, and use tire rack's spec sheets to find the revs per mile of your tire size. plug that into a calculator or make your own with excel and graph it.
www.xatracing.com/nissanrtSR20DET.html
1st 3.321 2nd 1.902 3rd 1.308 4th 1.000 5th 0.759
cdlong is offline   Reply With Quote
Old 09-03-2006, 10:12 AM   #4
cdlong
that seems overly elaborate. he isn't looking for speeds carried out to two decimal places, just seeing if his speedo is off.
i guess if that was the point, i can tell you right now. yes, it is, every speedo reads a bit high. but also your tires are 9.26% larger than stock. so in fact it reads low. to maintain the stock diameter you'd need a 245/35. or a 235/35 would be closer yet.
