Old 09-13-2006, 07:11 PM   #1
Ryencool
Ryencool is on a distinguished road
KA24DE Water Pump install.
So I'm about to replace the water pump after installing a new koyo rad last week (go figure the pump goes out the next week). Is there a write up anywhere for this and if not would one be wanted by anyone? Seems pretty straight forward but if anyone has info I might need to know that will help please let me know. Thanks!
Ryencool is offline   Reply With Quote
Old 09-13-2006, 10:02 PM   #2
projectRDM
projectRDM's Avatar
1) Remove old pump.
2) Install new pump.
3) Bleed coolant.
If you installed the radiator without issue, you don't need a writeup for the water pump.
Old 09-14-2006, 01:08 AM   #3
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Take off shroud, fan, fan clutch, then the pump.
Jung918 is offline   Reply With Quote
Old 09-14-2006, 02:26 AM   #4
sw20>>s14
sw20>>s14's Avatar
just make sure to tension the belt within the proper range...
sw20>>s14 is offline   Reply With Quote
Old 09-14-2006, 03:33 AM   #5
kandyflip445
kandyflip445's Avatar
Or it will go out faster than it should...
My 240 vBgarage
Old 09-14-2006, 06:55 AM   #6
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
As already stated:
- Drain coolant
- Remove belts (loosen brackets, etc.)
- Remove fan (4 small bolts)
- Remove water pump (few bolts)
It's easy.
Neejay is offline   Reply With Quote
