![]() I stumbled upon this online while searching how to change the auto tranny fluid on my brother's Camry. They are a few sample informative tutorials as well as repair tutorials, intended for automotive training. Even though they were samples, they were still very informative and simple. Not everyone here is an experienced grease monkey or a mechanics whiz, and not everyone has an FSM (or know how to use one), so hopefully this will be helpful to someone.
http://www.cdxglobal.com/resources/video.html For search purposes, video topics include: The lubrication system Using a bench grinder Disc brake pads Suspension force Checking an A/C system Using a DVOM to measure continuity Monitoring emissions Installing a solderless terminal 4-stroke engine cycle Repairing an external thread Replacing a fuel filter Functions of oil Using a two-post hoist Hydraulic shock absorbers Oil pump Setting up an oxyacetylene torch Parallel circuits Checking & cleaning a PCV valve Planetary gears Radiator pressure cap Replacing an engine drive belt Rack-and-pinion steering Rack-and-pinion gearbox Rotating tires Checking a seat belt Removing & replacing a disc brake rotor Using a screw extractor Checking & changing a spark plug Spark plugs Single-plate clutches Changing transmission fluid & filter Water pump Inspecting & testing a battery Using a floor jack more key words for searches: general maintenance repair tutorial online videos do-it-yourself DIY automotive training |
