Old 09-15-2006, 12:41 PM   #1
stickyrice
stickyrice is an unknown quantity at this point
power window question....
hey guys, my driverside power window switch doesn't seem to work. is this a common problem on s14's??? cuz i just bought a new but used switch adn it still doesn't work. is it the switch or the wiring or what?? but when i move the switch up and down i can hear a ticking noise but nothing happens. i know the regulator and the whole window assembly works cuz i can roll up and down the window if i connect the wire from the inside the door to a battery it works. so basically my question is it the switch or the wiring?
stickyrice is offline   Reply With Quote
Old 09-15-2006, 12:46 PM   #2
Shells
Shells will become famous soon enoughShells will become famous soon enoughShells will become famous soon enoughShells will become famous soon enough
1. Yes, common problem.
2. It could be the motor itself or the amplifier.
3. Search.
Shells is offline   Reply With Quote
Old 09-15-2006, 09:10 PM   #3
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
i second the post above.
Tenchuu is offline   Reply With Quote
Old 09-15-2006, 10:47 PM   #4
projectRDM
projectRDM's Avatar
I'd agree as well, but your chicken scratch ebonics writing makes my eyes bleed.
Old 09-16-2006, 11:31 PM   #5
street_white180sx
street_white180sx's Avatar
street_white180sx is an unknown quantity at this point
1.you tried a new switch and it didnt work.
2.you hard wired the motor and it worked.
3. it is the window amp. double check the wiring from the window amp as well though, and also check to make sure the window lock is off as well this gets alot of ppl of guard they wonder y the damn windows wont work but come to find out the lock was on.
1993 S14 Silvia Slant Top, Blitz Bov, Fmic, Catback exhaust, HKS evc 3
street_white180sx is offline   Reply With Quote
