Old 09-20-2006, 09:25 PM   #1
NA4NOW
NA4NOW is making his/her stupidity well-knownNA4NOW is making his/her stupidity well-knownNA4NOW is making his/her stupidity well-knownNA4NOW is making his/her stupidity well-known
RB25DET compression.
This 240 Im looking at has a rb25det swap. I asked the owner to do a compression test. He said the lowest was 135, and the highest was 145.
Does this sound like its in spec.?
NA4NOW is offline   Reply With Quote
Old 09-20-2006, 09:33 PM   #2
LB.Motoring
LB.Motoring's Avatar
155 across the board is what you want...
those are a little low ^
but understandable
not tooo bad, but 135 is a little low...
Robby Leuer
Old 09-21-2006, 07:28 AM   #3
eh?
eh? is an unknown quantity at this point
About 170 is spec. If the psi range is within 10 the motor is usually ok. But 135 is very low. It's possible to just have a gauge that don't read correctly. Is there no way you can test yourself?
eh? is offline   Reply With Quote
Old 11-26-2009, 05:26 PM   #4
AS240
AS240's Avatar
Trader Rating: (18)
AS240 is an unknown quantity at this point
Feedback Score: 18 reviews
bringing this one back from the dead.
i just compression tested my S2 rb25 while it was still warm. wot and fuel pump off. using a us general compression tester...i got 140 across all cylinders. the gauge didnt have a one-way valve so it would peak at 145 and drop back to 140. sound normal? i keep reading of people getting higher numbers and im a little concerned.
AS240 is offline   Reply With Quote
Old 11-26-2009, 08:55 PM   #5
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
over the years of natural wher and tear thats sounds about normal
fcdrifter20 is offline   Reply With Quote
Old 11-27-2009, 12:04 AM   #6
Zacho
Zacho is an unknown quantity at this point
nissan manual says rebuild 129 psi.
however, many different ways to go about compression testing.
Zacho is offline   Reply With Quote
Old 11-27-2009, 01:00 AM   #7
GSXRJJordan
GSXRJJordan's Avatar
Sounds like the motor's a little tired, but as long as they're all within 5 or 10 psi of each other, you're fine. Drive it.
Old 11-27-2009, 04:48 PM   #8
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
between 135 and 145 is a tad low , but the motor is still good , just a little used. i say go for it and take good care of the motor
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 11-27-2009, 06:24 PM   #9
BlitzRPS13
BlitzRPS13's Avatar
BlitzRPS13 has a little shameless behavior in the past
Did he do it warm or cold? Also it needs to be on a battery charger aswell.
BlitzRPS13 is offline   Reply With Quote
Old 11-28-2009, 04:26 PM   #10
AS240
AS240's Avatar
Trader Rating: (18)
it was warm and the battery is a fresh optima red top. i got the motor about a year or so ago and have been dailying it in my s13 since. i pulled the valve covers when i got it and it looked prestine. only had ~20km. its a strong motor. i made 315whp on a mustang dino with the stock turbo. im just curious because a 35r or a hx35 are my next plans. thanks for the replies
Old 11-28-2009, 04:32 PM   #11
BlitzRPS13
BlitzRPS13's Avatar
I would go ahead with it then.. and if you blow it up.. put forged pistons in it. If not.. enjoy.
Old 11-28-2009, 07:24 PM   #12
GSXRJJordan
Agreed 100% lol.
