Old 09-29-2006, 08:48 AM   #1
FinalDrive
FinalDrive's Avatar
FinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud of
Power steering leak!
I just changed the pressure hose on my '93 and I can't get a good seal on the lower flare fitting. The threads were sealed w/ teflon tape, but it squirts red ATF even at idle. Any suggestions?
Thanks in advance
FinalDrive is offline   Reply With Quote
Old 09-29-2006, 08:50 AM   #2
projectRDM
projectRDM's Avatar
Are both crush washers present? Without them it will continue to leak.
Old 09-29-2006, 09:51 AM   #3
FinalDrive
FinalDrive's Avatar
Both crush washers are on there where the pressure line bolts to the pump.
Are there crush washers for the flare fitting at the other end of the pressure line? I don't have anything on there other than teflon tape.
Old 10-01-2006, 07:09 PM   #4
FinalDrive
FinalDrive's Avatar
Hate to bump, but I still haven't sorted this out
Are there any tricks to getting a better seal on a flare fitting?
It appears to be leaking between the flare nut and its hard line, not the threads
Old 10-02-2006, 09:25 PM   #5
mrk9182
mrk9182 is an unknown quantity at this point
Send a message via AIM to mrk9182
if you are talking about where the line bolts to the rack there is a small oring that goes in there make sure they oring didnt get pinched
Mike
92 240sx coupe SR swap in process
02 Sentra SER SpecV
www.Badog.com
mrk9182 is offline   Reply With Quote
Old 10-03-2006, 09:20 AM   #6
FinalDrive
FinalDrive's Avatar
it appears that the flare end is slightly deformed
new hard line from the high pressure hose to the steering rack was ordered
thanks for the help guys!
