Old 07-06-2002, 08:27 PM   #1
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
IIRC Someone said that it is harder to swap in the SR into a 89-90 240. I think it had to do with the guages or something. Well I a m starting to plan my SR swap, which won't happen for about a year, and I need to know if its worth spending some extra money on a 91-94 S13 to avoid complications that the 89-90 would have.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 07-06-2002, 09:56 PM   #2
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
you need a newer tach/speedometer and powersteering lines. something about the A/C too. maybe it's a compressor, not sure. but it would be easier finding these parts, rather than finding a 5 speed in good shape and the options you want (and sales tax). even though it's an SR swap, finding a 5sp would mean less complications.
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
Old 07-07-2002, 07:02 PM   #3
AKADriver
AKADriver's Avatar
If you buy a whole SR clip, there's really not much reason to buy a manual trans chassis...  the only parts you'll need to finish the auto->manual swap are the hard line from the master cylinder to the "piping connector" and the "piping connector" itself (which are specific to LHD).
As for the '89-'90 chassis, you need the power steering lines and reservoir from a DOHC 240SX (again, a clip would have the right reservoir and a some of the lines, but a couple of the lines are LHD-specific).  You also need a tach from an SR or DOHC.
Old 07-07-2002, 08:11 PM   #4
Cheng
Cheng's Avatar
Cheng is an unknown quantity at this point
yup i just recently got an sr swap im my 89 90 240sx there were a few problem my mach encounter.  The tech for sure it doesn't work so you can buy an aftermarket one or just find a dohc cluster.  Thats what i did.  I don't think there is an need for power steering because you will be able to feel the road better if you really want the power steering be sure you get it the time of your swap don't do it later on.  I heard to if you take out the ac and ps you will be able to get more hp out of your engine because of the drag on the belts.
90' 240sx fastback
Mods:
Sr20DET:
(BLITZ: FM/IC, BOV, DOWNPIPE, INTAKE)
(5zigen Fireball 3" Exhaust)
(Bee R testpipe)
(Walbro Fuel Pump)
Cheng is offline   Reply With Quote
Old 07-08-2002, 10:47 AM   #5
Sick240
Sick240 is an unknown quantity at this point
Alright, well I will be ordering my engine in about a month, so What do I need to do to get the AC and PS to work? Also, what type or engine/tranny mounts do you guys suggest? Thanks
90 240sx Coupe
Sick240 is offline   Reply With Quote
Old 07-08-2002, 11:04 AM   #6
AKADriver
AKADriver's Avatar
<a href="http://www.heavythrottle.com/" target='_blank'>http://www.heavythrottle.com/</a>'s SR20DET FAQ has the answers you seek.
The KA and SR use the same engine mounts.
Old 07-09-2002, 09:43 AM   #7
Sick240
Yes they do use the same ones, but mine are basically shot, so should I just buy OEM? or is there a good brand I should look into? Thanks
90 240sx Coupe
