Old 10-21-2006, 11:59 AM   #1
92-sr20-s13
92-sr20-s13 has a little shameless behavior in the past
s13 sr20 tick/rattle sound coming from valve cover
So my sr is starting to make that infamous ticking sound..
the sound is like a very faint rattle or tick coming from the valve cover..
the car still runs fine and drives fun..just this little tick is always ther
and when i accel the rattle gets louder and faster..its not too too loud
like not realy noticeeable unless you try and listen for it..anyone know what
this could be? and should i park the car for now or keep driving it and take it
ezy or should i drive it hard once ina while lol..hopefully sumone can help me
with this..thanks!
92-sr20-s13 is offline   Reply With Quote
Old 10-21-2006, 12:22 PM   #2
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
mine does the same thing.. and its started to get a little louder over time... Part of it is your injectors clicking on and off.
But its also probably lifter tick as well
nsn240 is offline   Reply With Quote
Old 10-21-2006, 12:28 PM   #3
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
check to make sure its not your exhaust manifold gasket taking a crap on you. Ive heard that has caused a ticking sound for many people and many times it seems like its comming from somewhere else.
redsuns3838 is offline   Reply With Quote
Old 10-21-2006, 12:30 PM   #4
92-sr20-s13
i know its not the injectors..cuz i know that sound..im almost positive
its either the timing chain guide..or a noisy/brocken rocker. if it wer these
they would tend to make a sort of ticking or rattling right..and nsn240..after
you discoverd this noise..how did you drive your car and how long has it bin
i dotn wanna rip it then all of a sudden boom ther goes my sr lol
Old 10-22-2006, 05:57 PM   #5
misfitsfreak81
misfitsfreak81's Avatar
misfitsfreak81 is an unknown quantity at this point
its most likely your timing chain or related parts (ie chain guides, tensioner, ect..) if that chain breaks while you are driving it, whether it be hard or light driving, you are fcked. you will most likely have to perform an entire engine rebuild, it will wreck just about everything internaly. FSM has great step by step instructions on how to replace chain and such.
mike
misfitsfreak81 is offline   Reply With Quote
Old 10-22-2006, 06:08 PM   #6
Spec7
Spec7's Avatar
Spec7 is an unknown quantity at this point
If the rattling is apparent under any RPM load, my experience says that its a valvetrain/cylinder issue that needs to be addressed yesterday. If the rattling goes away after idle-3000 RPMS, its probably an exhaust leak.
Probably not what you wanna hear, but quit driving it until you find the culprit. Its much cheaper to fix it now than later when a sleaving or a stroker kit is required.
Not enough hours in the day to be nice all the time.
Spec7 is offline   Reply With Quote
Old 10-22-2006, 07:24 PM   #7
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
try bleeding your lifters....SR lifters must be blead manually. if a lifter is not blead it will make a tapping noise.
ladiesman8527 is offline   Reply With Quote
Old 10-22-2006, 08:51 PM   #8
92-sr20-s13
and how would i go about bleeding the lifters? lol sorry guys but your
help is greatly apreciated
Old 10-23-2006, 08:14 AM   #9
ladiesman8527
http://www.jgycustoms.com/infolinks.htm its about halfway down the page
Old 10-23-2006, 12:04 PM   #10
92-sr20-s13
i talked to my friend about it being the timing chain guide..he still hasnt
listend to the motor but he said it would realy suprise him because the motor
is fairly new..and the compression test read 150 140 140 140..im gonna try
to bleed the valves and then if its still an isue i guess take a look at the timing
chain
Old 10-24-2006, 11:52 PM   #11
GSXRJJordan
GSXRJJordan's Avatar
The JGY customs link was MONEY. Even though all that shit pertains mostly to nasty, ghey, FWD SR's, the bleeding instructions are awesome, and by the way, that's most likely what it is.
Old 10-25-2006, 12:09 AM   #12
nissanhpower
nissanhpower is an unknown quantity at this point
yeah take the valve cover off and take the guides off...
nissanhpower is offline   Reply With Quote
Old 10-25-2006, 11:36 AM   #13
nsn240
nsn240's Avatar
im 95% sure its not my timing chain... that shit it nice and taunt... im betting the problem with my car is either lifters or the ext. manifold gasket.
To the thread starter... i wasnt something that just started one day, i just kinda started noticing a little extra noise when the hood was up. If anything, a really loose timing chain might skip a tooth, but its highly unlikely that it would actually snap.
Old 10-25-2006, 12:02 PM   #14
Spec7
Spec7's Avatar
To check for the exaust manifold leak, feel around the turbo/manifold gasket. If there is a leak there, you will most likely feel the hot exhaust blow by.
Just as a disclaimer, dont touch the friggin manifold or turbo. It might just be hot.
Old 10-25-2006, 09:00 PM   #15
misfitsfreak81
hot enough to melt your skin instantly........ i know from experience. it sucks.
