Old 10-22-2006, 10:19 AM   #1
MOUNTAINGARAGE
MOUNTAINGARAGE's Avatar
MOUNTAINGARAGE is making a name for him/her selfMOUNTAINGARAGE is making a name for him/her self
Fusible link keeps blowing...Ideas?
First and foremost I searched. seems like all of the threads I have read resort to "Check your fusible link!"
So, I am here. I have spent 15.00 in fusible links.
I have checked the following:
Condensor fan wiring/relay - no resistance
Ignition/switch/column - no chafed/burnt wires
no other fuses blown anywhere in the car.
No accidents ever. <pinched wires>
no crazy electronics in the car.
Cooling Fans unplugged
Alternator unplugged
good battery -new this year
keeps poppin FSL's
Any Ideas? Ever happened to anyone else? link to FSM for 96 S14? zy is still down...
Thanks
MOUNTAINGARAGE is offline   Reply With Quote
Old 10-25-2006, 04:46 PM   #2
MOUNTAINGARAGE
yeah, still fightin the BS!! car goes up for sale soon.
I guess no one else has any probs like this?
Old 10-25-2006, 07:36 PM   #3
kandyflip445
kandyflip445's Avatar
No resistance in a circuit usually means a short. A short would cause too much curent leading to components failing (burning out/opens in the circuit). This is generally speaking though. Is the condenser fan/relay supposed to measure 0 ohms? Just doesn't sound right to me.
My 240 vBgarage
Old 10-25-2006, 11:13 PM   #4
projectRDM
projectRDM's Avatar
Very common problem on S14s is the coil feed wire chafing on the cylinder head. Look under the hood, where the harness exits the fuel rail area and make a turn across the front cover, right there in the turn the head has a sharp edge that the harness rubs against.
I've fixed three cars so far and diagnosed a handful more with that problem. The coil feed is the black/red main ignition, it blows the 75A link.
Old 11-05-2006, 05:08 PM   #5
stevebsvs
stevebsvs's Avatar
stevebsvs is an unknown quantity at this point
Send a message via ICQ to stevebsvs Send a message via AIM to stevebsvs Send a message via MSN to stevebsvs Send a message via Yahoo to stevebsvs
I have the same freakin problem...happens when ever I try to start the car and the battery is weak b/c of my dying alternator....if I crank for 5+ seconds, it pops the fuse...and I have 4 gauge wire run to the back for the battery...swapped that with welding cable wire...still pops the fuse
I'll look into this red/black wire. Thanks for the info, R240NA
stevebsvs is offline   Reply With Quote
Old 11-07-2006, 04:12 AM   #6
MOUNTAINGARAGE
Timeline: down for 2 weeks. after 90 for a tow back to the shop...I have kicked her to the curb. Back to driving my Jeep until more time is found to work on this.
6:15 a.m. Today- dressed in business attire, I read R240NA's post. walk outside with flashlight(still dark this early) Pop Hood, pull valve cover breather tube off, get hand dirty, twist harness near FL corner of cylinder head, see black/rusty grounding bolt, see hole on underside of harness, look closer and see shorted, melted harness, turn off flash light, shit pants, burst into laughter, Hug wife, rub kid on head, log onto Zilvia, type reply.
Man, this is why I am a premium member after 10 posts. I love you guys. R240NA mad props! pm me ur e-mail address.
Old 11-07-2006, 10:20 AM   #7
projectRDM
projectRDM's Avatar
And people call me an asshole, isn't that crazy?
Glad that's what it was, the first one I did took over 26 hours to track down, but after that one I know exactly where to look now. I even told a Nissan tech about it, he's fixed a few since then too. Until that point they were just swapping distributors and charging customers out the ass, hoping that was it.
Old 11-07-2006, 10:32 AM   #8
aznpoopy
aznpoopy's Avatar
r240na ftw
definitely very helpful
orange ilum wire behind the radio was blowing my tail lamp fuse. zilvia search + r240na responses = saving me time tracking down exposed wiring.
aznpoopy is offline   Reply With Quote
