Old 10-30-2006, 10:35 PM   #1
CNDC
CNDC is an unknown quantity at this point
Kouki HID DIY?
Hi, i was wondering if theres a DIY for putting H1 HID bulbs into the headlight.
I tried searching and i did find some information on good place to mount the ballast, but i need some help trying to get the bulb in. I was wondering do i have to remove that pin that holds the oem bulbs so i could put the HID bulbs in? I only ask this because i got a set of h1 HIDS and it looks like they don't fit right.
I also searched HIDplanet and there was nothing there about a DIY. Help would be appreciated thanks. Also if you know of anyother 240 sites that mite have this DIY. can you name them? thanks.
CNDC is offline   Reply With Quote
Old 10-31-2006, 06:09 PM   #2
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
http://www.frsport.com/s14-hid-headl...ors-p-726.html
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 11-03-2006, 04:39 PM   #3
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
Originally Posted by vutony
HAHAHA, almost like my writeup.
edit: I've seen a H1 philip 4300K kit on a kouki. It's not as bad as I really thought. There's a cutoff if adjusted correctly and it looks almost like a bmw e46 projector. It's not as sharp or not as much color. But the glare isn't that bad
There shouldn't be a writeup. Just pop out your old bulb, pop in the h1 hid bulb, mount your ballast somewhere, wire it up (using a stand alone relay harness) and plug the ballast to the bulb. It's not like you have to cut crap.
driftingisgay.com
nrg is offline   Reply With Quote
Old 11-03-2006, 09:14 AM   #4
Igor
Igor has a little shameless behavior in the past
nice man that should help alot of people.
Igor is offline   Reply With Quote
Old 11-03-2006, 09:35 AM   #5
S14DB
AFC #1
S14DB's Avatar
I prefer to use the HID planet kit over the S2000's. 1, they are new. 2, people want as much or more for just the S2000 housings on ebay.
http://www.hidplanet.com/package.html
Old 11-03-2006, 09:48 AM   #6
vanish1
vanish1 is not welcome here anymorevanish1 is not welcome here anymorevanish1 is not welcome here anymorevanish1 is not welcome here anymorevanish1 is not welcome here anymorevanish1 is not welcome here anymorevanish1 is not welcome here anymorevanish1 is not welcome here anymore
SICK 240sxforum writeup on a S2K retro into a Kouki
http://240sxforums.com/forums/showth...t=HID+retrofit
vanish1 is offline   Reply With Quote
Old 11-03-2006, 10:35 AM   #7
NemeGuero
No more nissan.
NemeGuero's Avatar
ballerific..
Old 11-03-2006, 11:01 AM   #8
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
hmm has anyone tried a retrofit of hid's on a zenki before?
SilviaSR20DET is offline   Reply With Quote
Old 11-03-2006, 12:52 PM   #9
CNDC
thanks for the replies, but i was wondering if anyone has a DIY for HIDS in stock projectors or if theres some special step u need to do to fit the bulbs in the headlights.
Old 11-03-2006, 01:08 PM   #10
chmercer
chmercer's Avatar
lol, what?
put bulbs in headlight
plug bulbs into ballast
plug ballast into wiring harness
turn on headlights
chmercer is offline   Reply With Quote
Old 11-03-2006, 01:19 PM   #11
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
the heck are you talking about? you dont know how to change a couple bulbs? you sure you got h1? pull your halogens and check the base to see if they're the same. ballasts just mount wherever its dry. theres not DIY for rebased hid kits cuz they're pretty straight forward.
kensreliableb18b is offline   Reply With Quote
Old 11-03-2006, 01:58 PM   #12
vanish1
HID kits are ass, OEM HID retrofit is the only way to go
Old 11-03-2006, 11:20 PM   #13
CNDC
well i did get h1 bulbs tried to install them. However, it was a tight fit and i ended up braking one of my hid bulb. there was a pin holding in the halogen ones. so i was wondering if i need to remove it? i wasnt sure because i could get the bulbs in but it would go in at a angle because i guess the base of the bulb is to big? i was just wondering if i needed to take anything off the stock setup so i could fir the rubber base in there.
Old 11-03-2006, 11:23 PM   #14
chmercer
chmercer's Avatar
lol. UGH. the clip holds the bulb in. you push in on it and to the side to pop it out.you dont just try to cram it in the hole. go to autozone and ask the guy behind the counter to change your headlight bulbs if you cant figure it out.
Old 11-06-2006, 10:27 PM   #15
CNDC
im not that much of a noob. lol. i meant take out the pin tottally. like unscrew it and take the whole thing out cause i found it annoying and it got in the way. sorry i didnt clarify that.
Old 11-04-2006, 03:53 AM   #16
yokotas13
yokotas13's Avatar
this is simply hilarious
yokotas13 is offline   Reply With Quote
Old 11-04-2006, 04:33 AM   #17
avs0730
avs0730's Avatar
avs0730 can only hope to improve
Send a message via AIM to avs0730
i have been looking for this for a while now
avs0730 is offline   Reply With Quote
Old 11-08-2006, 01:31 AM   #18
blownoffvalve
blownoffvalve is an unknown quantity at this point
thanks to VUTONY!
blownoffvalve is offline   Reply With Quote
