Old 11-02-2006, 10:45 PM   #1
Realnez
Realnez's Avatar
Realnez is an unknown quantity at this point
Send a message via MSN to Realnez
finally Ka-t installed....but not running right???
hey everyone I finally turbo'd my DOHC KA in my s13, Im running sr injectors, fmic, T25 and SAFC2,N60 MAF (blowthrew setup mounted by the TB). I finally got it in and shes starting up but its idling very weird. First off my idle says above 2000RPM and doesn't want to come down. Secondly when I touch the throttle is stumbles etc. Im going to try a different vaccume source because I tapped into a line that used to go into the air intake (Im a noob). Also I noticed a bit of smoke comming from the turbo, is it just burning the excess crap off?? Its a T25 with oil and coolent lines and I only have the oil lines hooked up. I will post up a vid of the problem in the next about 20 mins, does anyone know where to tap in the vaccume line? LMK asap I need my car to get to work tomorrow haha.
Safc 2 Settings
HW In 2 out 5
All settings are on 0% because I had it in while N/A (I dont know what to set it too)
thanks
James
Realnez is offline   Reply With Quote
Old 11-02-2006, 11:39 PM   #2
NemeGuero
No more nissan.
NemeGuero's Avatar
I don' think your maf is wired up right.
Old 11-03-2006, 12:27 AM   #3
Bbandit
Bbandit's Avatar
Bbandit is an unknown quantity at this point
Send a message via ICQ to Bbandit Send a message via AIM to Bbandit
In blowthrough setup.. your MAF should be a couple of inches away from the TB. I forgot about the optimum distance.. its been a long time since i did research for my old ka-t.
as for vacuum lines,
this is what i did in my old ka-t,
Weld a nipple on the hotpipe, and connect a vacuum hose to the wastegate nipple (add a boost controller solenoid here if you have one).
Theres another nipple on the intake manifold, use that for blowoff valve & boost gauge (using T junction nipple).
Search for older ka-t posts (like in 2003-2004), theres a bunch of uselful infos in those posts/threads.
look for AceInHole posts.. he was one of the ka-t pioneer.
and of course you need to tune that SAFC right, I have never used SAFC before so I can't really help.
I suggest finding someone with similar setup and consult.
as for the smoke.. its probably some excess stuff.. or maybe it has something to do with your safc tune... or maybe the turbo seals are going out (unless if you already rebuild the turbo)
Good luck
==>>TGL GARAGE<<==.. RIP!
S13 coupe KA-T @ 0.5 Bar = SOLD!
A31 Cefiro + SR = Current
Bbandit is offline   Reply With Quote
Old 11-03-2006, 12:33 AM   #4
mistaanime
mistaanime's Avatar
mistaanime is making a name for him/her selfmistaanime is making a name for him/her self
Send a message via AIM to mistaanime
just run stock maf..its not like you can go that serious with a t25 anyway.
-Cherry Red 91 Silfourty-
mistaanime is offline   Reply With Quote
Old 11-08-2006, 04:02 AM   #5
1Via!
1Via!'s Avatar
1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all
Send a message via AIM to 1Via!
And think about going somewhere to do a "tune" on the safc. A place that knows what its doing and has experience can produce good results in about an hour. This has been the experience with a few friends of mine with safcs.
SAFC=:ghey: but thats a different story.
1Via! is offline   Reply With Quote
Old 11-08-2006, 02:50 AM   #6
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
show some pix...
if it stumbles it kould because of maf. check what ur car is tryin to at boost out at all times... it might of spiked. check if waste gate if good too. im not turbo yet but these things you should check before you blindfold install.
check all ur vac. be sure there isnt a leak
bo2o is offline   Reply With Quote
Old 11-08-2006, 08:32 AM   #7
nelson8708
nelson8708's Avatar
nelson8708 is making a name for him/her selfnelson8708 is making a name for him/her self
With a T25 the stock maf doesnt max out until about 10psi. I dont even know if a t25 will push that on a ka. I am only running seven psi on my T25. Dont want to go any higher than that for the turbo's sake.
Go here for all your safc questions...
http://www.ka-t.org/forums/viewtopic...ght=safc+guide
KA24E-T boosted for one year now.
nelson8708 is offline   Reply With Quote
