Old 11-03-2006, 09:04 AM   #1
91rps13
91rps13's Avatar
91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice91rps13 is just really nice
another 240 that fails state inspection
i search and read the other guys attempt to pass inspection but i still have a few ?? plus i dont know if my readings apply to the other threads..
first of all i live in texas and i fail the state inspection on thursday.
my readings wherelow speed emission results 815 rpm)
standard reading
HC 220 275
CO% 1.20 2.32
i passed the high speed though..
the guy that did the test told me that i should get my cat converter cuz it might be dirty and my whole exhaust for leaks..
should i do that???
i dont want to waste much money since i have alot of bills to pay..
or should i just do the other stuff mention in past threats
o2 sensor
egr
coolant temperature sensor
vaccums
before doing the inspection
i changed to ngk iridium, changed my oil(about time), and used some intake cleaner
plz help.... i have 15 day to get another inspection so i need to start replacing and cleaning....
thanks....
No more 240
91rps13 is offline   Reply With Quote
Old 11-03-2006, 01:58 PM   #2
AuburnRyan
AuburnRyan is an unknown quantity at this point
Did you really rev it and get your cat nice and hot before inspection? Run it hard right before you go in...
Makes a world of difference.
'93 Fastback LE - Wrecked
'91 Fastback HICAS and LSD - Sold
'93 Fastback SE - Current
AuburnRyan is offline   Reply With Quote
Old 11-03-2006, 02:32 PM   #3
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Did you use seafoam or was it some off brand stuff? Seafoam does wonders, and also, clean out the egr and iacv vacuum lines while youre at it. The egr system gets teh nazty.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 11-03-2006, 07:13 PM   #4
BOROSUN
BOROSUN's Avatar
BOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfection
looks like your running rich = co. hc can rise either way rich or lean.
check the fuel delivery/injectors/fuel pressure
& dirty air filter
or could be faulty input sensor, like ect.
also yeah running rich usually kills the cat.
BOROSUN is offline   Reply With Quote
Old 11-06-2006, 08:07 AM   #5
91rps13
91rps13's Avatar
you guys think i should get my cat checked.. it would really suck failing again
No more 240
Old 11-06-2006, 08:08 AM   #6
91rps13
91rps13's Avatar
oh i had my filter replaced like 2 months ago and my injectors cleaned in some shop
No more 240
Old 11-06-2006, 11:03 PM   #7
Captain_Impossible
Captain_Impossible is an unknown quantity at this point
How long had it been between the time you last started the car and when you took the test. For the cat to work its best it needs to be hot. This means on the way to emissions you should drive the car hard.
Captain_Impossible is offline   Reply With Quote
Old 11-07-2006, 10:24 AM   #8
91rps13
91rps13's Avatar
i drove for a few minutes only... ill drive hard next time thanx..
i went to a muffler shop and its like $90 for a new cat installed... i dont want to do it though cuz i am planning on buying a 3" exhaust i know its not gonna pass inspection either but thats why i wanna pass it before installing it.
so im working around the cat hopefully thats not whats making my car fail.. if not am gona have to "waste" my $90
if any one knows of anything else please let me know.. oh am also gona clean my maf sensor(it was from a junky car)
No more 240
