Old 11-07-2006, 08:41 AM   #1
TurbLu
TurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-known
SR having WOT issues!!!??
I am having a mild issue right now. It only happens at WOT(Not even under boost)... in any gear at any RPM if I go WOT the car just falls flat on its face. Almost like a fuel cut or spark cut. But I can give it up to like 99% throttle as long as I dont hit the floor with it and it drives and accelerates normally. I have no codes being thrown? Im almost positive its electrical at this point. I was running lean due to a fauly megan FPR so I went back to stock and havent seen white plugs since. So what else could it be?
TurbLu is offline   Reply With Quote
Old 11-07-2006, 09:29 AM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
have you checked your maf?
Slip Gypsies Blog
not sure if you realize this
Old 11-07-2006, 01:46 PM   #3
SoSideways
SoSideways's Avatar
TPS sensor? WOT switch? Which SR do you have?
Old 11-07-2006, 09:51 PM   #4
TurbLu
Red Top SR... please help me narrow down which items to check out...
Also how do I test the TPS and WOT switches???
Old 11-07-2006, 11:40 PM   #5
TurbLu
One more thing... during a FPR change over it leaked gas all over the tps area. Do you guys think it could've ruined it in any way. Pretty doubtful because the car ran fine for a few days after. Then after a hard run is when it started doing this. I checked my plugs and # 1 was white and it got darker as I got farther down the engine. So I swapped back a NEW factory FPR. The car doesnt run lean anymore but the car still wont let me WOT her!!!
Old 11-08-2006, 12:20 AM   #6
GSXRJJordan
GSXRJJordan's Avatar
I'm 90% that its TPS. Ideally you'd want to see what voltage the tps is getting, and find out whether it puts out that same voltage at WOT... first try pulling out the TPS plug and spraying some contact cleaner in both the plug and its receptacle, and letting it evaporate. Then plug it back in a few minutes later, let the car warm up, and try it. Definitely sounds like a full TPS check would show it volting up correctly right up until WOT, then showing drastically lower volts at WOT, but could just be the plug.
Also could have to do with MAFS, but I doubt it if its strictly throttle dependent.
Old 11-08-2006, 08:46 AM   #7
TurbLu
Thanks, Im going to research in the fsm just how to exactly test the TPS sensor. Now if it is bad, where can I get a replacement?
