Old 11-07-2006, 09:13 AM   #1
blue2turbo
blue2turbo is an unknown quantity at this point
Send a message via AIM to blue2turbo Send a message via Yahoo to blue2turbo
Clutch pedal missing piece??
Can someone tell me for sure if there is a piece that goes into the pedal that I am missing and what it looks like? Even better, if you know what it is, and you even have it for sale or know where I can get it. Please let me know... its a pain to start the car. thanks!
[email protected]
blue2turbo is offline   Reply With Quote
Old 11-07-2006, 09:57 AM   #2
Annoying Eric
Annoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura about
Send a message via AIM to Annoying Eric
Theres a little rubber piece (IIRC) that goes there. It pushes in that switch you see behind it. Its a safety switch so you cant start the car while its in gear.. Just take a bolt and put two washers on each side with a nut and you should be fine..
Annoying Eric is offline   Reply With Quote
Old 11-07-2006, 10:08 AM   #3
projectRDM
projectRDM's Avatar
^ Bingo, or just remove the switch and jumper the plug together.
Old 11-07-2006, 10:50 AM   #4
blue2turbo
Well thats as easy as I had hoped. i will probably just buy one of those oversized interior pins and push it up on in there with the flat side toward the button. I need some for my trunk paneling anyways
