Old 11-11-2006, 04:44 PM   #1
llteddy4playll
llteddy4playll is making his/her stupidity well-knownllteddy4playll is making his/her stupidity well-knownllteddy4playll is making his/her stupidity well-knownllteddy4playll is making his/her stupidity well-knownllteddy4playll is making his/her stupidity well-known
heavy white smoke!!!!!!!
Everything was fine untill i installed 740cc and enthalpy. After the install the car is constantly blowing white smoke and it smells like fuel. Before it was fine and i checked for leaking injector and its good. What else could be wrong? Bad tune or what?
llteddy4playll is offline   Reply With Quote
Old 11-12-2006, 02:34 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
white smoke usually means coolant. Check your compression, something could have gone wrong before you installed it. As far as the fuel, enthalpys tunes are still usually rich which could explain the fuel smell.
CLICK HERE!!!
Old 11-12-2006, 02:54 AM   #3
gotta240
FYI, typically smoke colors go as follows
white- coolant/water
blue- oil
black- rich
Are you sure its WHITE? If so, i'm guessing bad head gasket... Start with a comp. check and work from there.
Old 11-12-2006, 12:36 PM   #4
llteddy4playll
This is a brand new motor. Compression test is good. The smoke is white with a lil black smoke. No smell of coolant watsoever only fuel. I just noticed today that the enthalpy ecu led is constantly on. I had a friend that had that problem and he sent it back and got it fixed somehow.
Old 11-12-2006, 01:48 PM   #5
GSXRJJordan
GSXRJJordan's Avatar
The ECU light is gonna be on whenever the ignition is turned on. Sounds like you've got a mismatched ECU/injectors, as long as you're positive compression's good. I'm assuming you dont have a wideband to doublecheck, but how's throttle response off idle? Does the car run at all?
Old 11-12-2006, 02:58 PM   #6
bardabe
bardabe's Avatar
well when I blew an injector O-Ring I got massive white smoke. so white is not always coolant. FYI.
Review Thread
bardabe is offline   Reply With Quote
Old 11-12-2006, 05:36 PM   #7
llteddy4playll
It idles and rev perfect. Just blow smoke. But to make sure all you do is take out the fuel rail off the manifold and see if theres fuel leaking from the bottom right?
