Old 11-12-2006, 12:56 PM   #1
DisEpyon
DisEpyon's Avatar
DisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to behold
Send a message via AIM to DisEpyon
bov question
i have a 7 psi tial bov and when the car is on idle it opens up about half way causing a leak and the motor doesnt idle right. i put my brothers 11 psi spring bov on and it still opens up a little bit and the motor still doesnt idle right. but when i plug up the vac hose to the bov it idles perfect. my bov is on my cold pipe. do i need a higher spring? my boost guage reads at -20 to 22.
please help me.
thanks, brent
DisEpyon is offline   Reply With Quote
Old 11-12-2006, 01:26 PM   #2
misfitsfreak81
misfitsfreak81's Avatar
misfitsfreak81 is an unknown quantity at this point
where are you running the vacume source from? do you have it tee'd to anything else?
misfitsfreak81 is offline   Reply With Quote
Old 11-12-2006, 01:39 PM   #3
crazybb
crazybb is on a distinguished road
my buddy had the same problem and he had to put a stiffer spring to make it work
crazybb is offline   Reply With Quote
Old 11-12-2006, 01:46 PM   #4
GSXRJJordan
GSXRJJordan's Avatar
yeah, the BOV isnt just supposed to work on a spring, it needs its own (non tee'd) vacuum line connection from the coldpipe or the throttle body. It shouldn't matter which side of the intercooler your BOV is on, although most of us run them closer to the turbo.
Old 11-12-2006, 02:46 PM   #5
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
vaccum is def your problem...
you should recirculate it....even if it still leaks you wouldn't run into the idle problem with it recirculated
sean350z is offline   Reply With Quote
Old 11-12-2006, 03:38 PM   #6
DisEpyon
DisEpyon's Avatar
right now i have it connected to my manifold and teed off with the wastegate.
so i guess i shouldnt tee it with the waste gate? then itll run better?
Old 11-12-2006, 04:12 PM   #7
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
yes you should run it straight to one of the vacuum lines under the throttle body
Slip Gypsies Blog
not sure if you realize this
Old 11-12-2006, 04:37 PM   #8
S14DB
AFC #1
S14DB's Avatar
Make sure you have the right spring for your application:
http://www.tialsport.com/documents/w3_tial_bov50_sp.pdf
Old 11-12-2006, 07:37 PM   #9
DisEpyon
DisEpyon's Avatar
ok, after hooking the wastegate up to one of the vac sources under the mani, its much better. on the 11 psi spring. cause i know for a fact that my 7 psi is way to soft. my boost guage is ranging from -20 to -22, more around -21. so do you think that 11 psi spring is perfect? it still opens up just a little bit when on idle. but idles alright still.
now i have another problem for anyone that knows. today after fixing that problem and bleeding my brakes and clutch, i got to drive my car for the first time. but the problem is ,when i push in the clutch ,the car dies out on me or stalls. so for instance , when i try and take off and push the clutch in to 1st gear, it will die, so i have to gas it or itll die. then when going around a corner coming out of 3rd gear trying to put it in 2nd gear itll die out on me.
and also, where can i buy a new throttle cable, cause the one im using doesnt work great. before it was too short at the end where it goes to the tb and to my bracket, so i had to customize it and make it longer, but it still doesnt work out great. right now i have it bolted in the two holes on the greddy intake mani, cause i couldnt figure out a way to get a bracket or make one. could it be the angle or what?
thanks, brent
Old 11-12-2006, 09:42 PM   #10
DisEpyon
DisEpyon's Avatar
had help figuring out my car stalling problem. it all adds up to being the bov. the tial bov is a vented and not a recirculating one. like i should had bought.after i pluged up the blow off valve the car didnt stall out on me when pushing the clutch in anymore. but now i have another problem, is there a way to make my tial bov work, cause im not buying a new bov. i was told there is a system that helps bybass the maf sensor to make the bov work. and i guess 11 spring is good for me?
thanks, brent
Old 11-12-2006, 09:56 PM   #11
S14DB
AFC #1
S14DB's Avatar
I would get the -12psi spring to keep it closed if you are having launch problems. When you let out the clutch the engine sees more load and the vac goes up opening up the BOV and allowing unmetered air in. Should be soft enough to still blow off effectively when you let off the gas.
What are you using for management? Stock ECU?SAFC?
Old 11-13-2006, 03:45 AM   #12
Bay_Area_sr20det
Bay_Area_sr20det is a well-known jackass
Send a message via AIM to Bay_Area_sr20det
could juat get a pull type, will never leak on idle.
Speed Kills, Drive A Honda Live Forever!
Bay_Area_sr20det is offline   Reply With Quote
Old 11-13-2006, 10:05 PM   #13
DisEpyon
DisEpyon's Avatar
yes i am running stock.
would the hks vpc system be the best way to get rid of this problem or is there another way to do it easier?
what do you mean by a pull type?
Old 11-13-2006, 10:18 PM   #14
spdfreek0o
spdfreek0o will become famous soon enoughspdfreek0o will become famous soon enoughspdfreek0o will become famous soon enough
Send a message via AIM to spdfreek0o
go blowthrough
spdfreek0o is offline   Reply With Quote
Old 11-13-2006, 10:21 PM   #15
smelly240
smelly240's Avatar
VPC are hard to find IIRC - you can use www.map-ecu.com (similar to VPC and used a lot in supra communities) or use powerFC D-Jetro or AEM. or megasquirt, or haltec, etc.
Theres also the option of runnin blowthrough - which i did for a long time and it worked good but i went back and remembered how much i liked the insta-flame get off my ass in traffic "mechanism" with the blowthrough it still spews toasties runnin it hard tho
I'm just trying to list options for oyu to look at since VPC is old stuff that i havent seen in a while.
edit** VPC is still effin expensive - 700+- bucks **
if you dunno what blowthrough is - its running the maf in your cold side IC piping - you'd have to move oyur bov to the hot side for this. you also need as much straight pipe as you can get on each side of it - and you should use a Z32 maf - stock ones made my car run funny.
pull type is a HKS SSQV or racing Type II (400+$) maybe the apexi dual one??? not sure -
smelly240 is offline   Reply With Quote
Old 11-14-2006, 10:50 AM   #16
DisEpyon
DisEpyon's Avatar
out of all those options you listed , which would be best ,yet cheapest and easy?
im not doing blow through, cause i dont want to redue all my pipeing and bov.
Old 11-14-2006, 11:26 AM   #17
SoSideways
SoSideways's Avatar
Getting the correct spring for your BOV would probably be the easiest/cheapest way to go around it. Also, check to make sure that your BOV is seeling the vacuum signal from the correct vacuum port.
I used the top right nipple from the intake manifold IIRC just above the throttle body on my S13 black top engine.
If all else fails, seems like you need a new BOV. If that's the case, PM me and I'll get you a good deal on the HKS SSQV BOV.
