Old 11-22-2006, 03:30 PM   #1
Sneaker Chimp
Sneaker Chimp's Avatar
Sneaker Chimp is an unknown quantity at this point
Send a message via AIM to Sneaker Chimp
dumping crazy oil!!!!
alright well i just did a 95 ka24de swap into my fastback. everything is plugged in the car starts, but when i start it, it dumps ALOt of oil i just put in 4 quarts of oil and 1 or 1 1/2 of the oil got dumped out..The leak is coming from the same side as the oil filter from the look of things it looks like its coming from above the oil filter area but around the same area. Theres no hole in the block and the oil filter housing gasket is fine. Anyone know where else i should look???? this is starting to irk the shit out of me...PLEASE help!!!!
"How now brown cow. how now brown cowwwww"
Sneaker Chimp is offline   Reply With Quote
Old 11-22-2006, 03:34 PM   #2
Ninjabread
Ninjabread's Avatar
My guess is when you took off the old filter, that rubber gasket got caught, and now you have 2 gaskets and its leaking... happened to a buddy of mine before. Just take your filter off to check and make sure the surface on the block is clean.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 11-22-2006, 03:38 PM   #3
Sneaker Chimp
yeah i did that. the area was clean before i put on a new gasket. but its not the actual oil filter gasket its the housing part that the oil filter screws onto. i changed that gasket and it still dumps oil. ALOT of oil.
Old 11-22-2006, 03:47 PM   #4
Ninjabread
Ninjabread's Avatar
Cracked block?!
613DriftWerks.ca
Old 11-22-2006, 03:51 PM   #5
Sneaker Chimp
well before i swapped the motor i checked for any cracks or holes i didnt see anything..but im not ruling that out. i'm just trying decypher any other possible problems.. if all else fails im probably come to the cracked block conclusion.. thanks
Old 11-22-2006, 03:53 PM   #6
Ninjabread
Ninjabread's Avatar
ugh, i hope for you that it's not.... hopefully someone else will chime in.
613DriftWerks.ca
Old 11-22-2006, 03:55 PM   #7
Sneaker Chimp
same here...thanks though...
Old 11-22-2006, 07:34 PM   #8
Sneaker Chimp
anyone else want to be helpful?
Old 11-22-2006, 10:32 PM   #9
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Clean the engine up at look to see where it is comming from. That is really all you can do. It has to be quite a major leak though if it dumps that much oil out so it shouldn't be too hard to find.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 11-23-2006, 12:28 AM   #10
Sneaker Chimp
yeah, i've come to the conclusion that im going to pull the motor back out since the swap isnt that hard. I'm gonna clean it and inspect...thanks
Old 11-23-2006, 06:21 AM   #11
techn9ne
techn9ne's Avatar
techn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the rough
Send a message via AIM to techn9ne
you sure you didnt double gasket it?
techn9ne is offline   Reply With Quote
Old 11-23-2006, 08:53 AM   #12
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
maybe you should put the oil switch where it belongs and not forget to screw it in next time
hydropgrahics!
ls1......
Old 11-23-2006, 11:24 AM   #13
HyperTek
oil switch/sensor, should be right next to that area
Keep it Classy
Old 11-23-2006, 12:19 PM   #14
Sneaker Chimp
LOL it's in...its been in. its coming from ABOVE the filter.not the bottom right corner of the filter....
Old 11-23-2006, 09:58 PM   #15
420sx
420sx's Avatar
ok then take off the filter make sure the old gasket isnt on there lol
hydropgrahics!
ls1......
Old 11-24-2006, 04:41 AM   #16
Sneaker Chimp
^^^ its not coming from the OIL FILTER...
