Old 11-23-2006, 06:10 PM   #1
mattx7
mattx7 is an unknown quantity at this point
sr idle issues.
heres all i know.
its an 89 s13 coupe with a redtop sr20det.
the idle doesnt surge up and down when its cranked so it didnt seem like a vaccum leak.
the maf is good, its a sohc maf, running the sohc maf plug.
aicv is clean, vaccum pressure is at 17 at idle, compressions is 150ish on each cylinder. im running open dp. new plugs, new fuel filter.
the 02 sensor is not connected and where its supposed to go in the turbo extension. theres a peice of pipe threaded in there and pinched shut.
it holds idle fine when its stopped, i can push the clutch in while in gear it will hold idle, put in in neutral when its stopped and it will hold an idle.
when im driving, it hessitates terribly when it hits boost... i let off the gas and it backfires alot...ALOT. and if i put it in neutral when driving it stalls. when i push the clutch in when driving it stalls unless i put it into gear really fast and give it gas.
mattx7 is offline   Reply With Quote
Old 11-23-2006, 06:33 PM   #2
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
lol
buy/build an exhaust?
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 11-23-2006, 06:56 PM   #3
mattx7
do you think i just dont have backpressure? that was another thing i was wondering about.
Old 11-23-2006, 07:07 PM   #4
koukimonster139
no shouldnt really matter it is turbo right
anyway im guessin your gonna want to throw an o2 sensor in it.
ho ha ho chi chi
Old 11-23-2006, 07:24 PM   #5
mattx7
so you think the 02 senser may be the cause, im new to fuel injection.
sorry man im used to a carb'd rotary.
Old 11-23-2006, 07:39 PM   #6
abunai the drifter
abunai the drifter's Avatar
abunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-known
Send a message via Yahoo to abunai the drifter
sounds like u need to swicht to a sr maf or a z32 and ur vac should be at 20in of murcury try
abunai the drifter is offline   Reply With Quote
Old 11-23-2006, 07:40 PM   #7
mattx7
you know what, i just put new plugs in about 3 days ago, last night i looked and the injectors werent grounded... grounded them and they turned on and sure enough, pulled the plugs and they were fouled. would leaky injector o-rings cause me to stall while driving but not at idle?
Old 11-23-2006, 07:49 PM   #8
koukimonster139
no, but flooding the engine due to the ecu thinking its running rich due to no o2 sensor might...
also you need the sr maf
ho ha ho chi chi
Old 11-23-2006, 08:40 PM   #9
mattx7
wouldnt it do that at idle while stopped as well? i mean it sits there for the longest time in neutral with no problem. i rev it and it doesnt hessitate when its not driving.
Old 11-23-2006, 09:49 PM   #10
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
u need to get bkr7e plugs. the plugs ben put in the car were from my car. they are old and fouled out.
u need to get
a) an sr maf.
b) check for vacuum leaks.
the maf is the problem im 90% sure
hydropgrahics!
ls1......
Old 11-24-2006, 04:24 AM   #11
mattx7
u need to get
a) an sr maf.
hey alex. i got bkr7e's in there... they fouled out allready.
ben and i check for vacuum leaks and had no sign of one. i think it may be the maf as well. my question is, wouldnt the maf affect it at idle as well? itsw only while the car is rolling. ben wired the plug from an sohc maf in right? and were running the sohc maf. i may try to get ben to rewire the sr plug in and try his sr maf as a test.
Old 11-24-2006, 11:45 AM   #12
mattx7
o2 sensor is in, car acts like it doesnt have backpressure.
alex, ive heard of people running the sohc maf on the redtops, i dont know what to think about it. i havent been able to get hold of ben for like 3 days and i need my car on the road soon. the transmission on the truck is fucking up. i cant afford to be without a vehicle. im going to put an exhaust on it tonight just for the sheer hell of it to see if it works. hell, ben looked for like 5 hours for a vacuum leak and couldnt figure out why it wouldnt hold an idle. then we just put the intake filter on and it idled. so what could it hurt to just try.
Old 11-24-2006, 03:03 PM   #13
mattx7
which reminds me... its the maf haha. im pretty much positive it is.
Old 11-25-2006, 11:35 PM   #14
420sx
420sx's Avatar
just like i told u before. stop tripping out. its the maf
hydropgrahics!
ls1......
