Old 11-24-2006, 04:44 PM   #1
bamaboy
bamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfectionbamaboy is close to perfection
suspension questions
Maybe someone will have some insight to whats going on with my car. I have an 03 track model 350z. Every time I turn to the left I hear a popping sound coming from the front left side of the car. I put the car up on a lift today, pulled on every moving part I could find, turned the wheel, compressed the suspension....and nothing. I also here the sound when I go over speed bumps.
Right now you are my biggest fan. You are to me what a sex tape is to Paris Hilton, not the best publicity in the world, but at least I'm on people's mind and it has something to do with a pussy!!! HAAHAAAAAAA
bamaboy is offline   Reply With Quote
Old 11-24-2006, 04:50 PM   #2
gotta240
hmm. any aftermarket suspension?
have you checked tie rod ends?
Old 11-24-2006, 06:38 PM   #3
superduner
superduner's Avatar
superduner can only hope to improve
this might sound dumb.... but PERHAPS you migh've droped the car and the tire is somehow hits the fender from the inside on those occations (PERSONAL EXPERIENCE on my 240z) also u might want to check the shock being good if its not the supention is not being rebounded back down and ur tire hits the fenders. if you cold give us a little bit more insight on a somewhat more PRECISE sound it makes or other ocations the car makes that sound does it sound like the type of noise a messed up halfshaft on a FWD car makes or something like that that would help us give u mire feedback.
Just tyring to help
superduner is offline   Reply With Quote
Old 11-24-2006, 07:19 PM   #4
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
it sounds more like a broken tie rod, thats what they usually do, but it doesnt seem like that would be the case since its only a 2003
Slip Gypsies Blog
not sure if you realize this
Old 11-24-2006, 10:21 PM   #5
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
The feathering problem has gotten worse.
I think it is one of the ball joints.
Jung918 is offline   Reply With Quote
Old 11-24-2006, 11:18 PM   #6
KwKouki
KwKouki's Avatar
KwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfection
Send a message via AIM to KwKouki
check to see if your springs are seated properly. my s13 did the same thing when I switched out springs for the first time.
KwKouki is offline   Reply With Quote
Old 11-25-2006, 05:39 AM   #7
jmauld
jmauld is making a name for him/her selfjmauld is making a name for him/her self
Send a message via AIM to jmauld
Engine/tranny mounts will also make a popping noise if they're loose.
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
Old 11-25-2006, 07:20 AM   #8
driftenthusiast
driftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to all
Stock suspension?
driftenthusiast is offline   Reply With Quote
