car dont idle
built up my ca18det and it doesn`t idle at all !!!
i can hold it only with the gas pedal and its strange like it response to the pedal if i get of the gas it stalls, if i step on it lightly the engine rev up to 2000rpms (even with little throtle) and stalls again, if i pump with the throtle i can keep it from stalling but it rev up to 2000rpm`s again and stall again. i cant keep the engine with the throtle at rpm`s, like 1500 ore 2000rpm`s it revs up alone and stall afterwards the mods are s15 turbo power fc 534ccm injectors + fuel pump z32 afm 270° tomei 8.80 lift cams lighten crankshaft/ flywheel ( all togheter about 4,5 kilo less weight with pistons and rods) forged piston/rods (compression ratio 8,2 :1) mhg with studs s15 turbo with these mods it doesn`t idle and was backfiring heavy to test i was going back to stock cams to figure out what the problem is, the backfiring is gone now but it doesnt idle, like i wrote above the a/f is right about 12,5 :1 under load i cant realy check my ignition timing when car doesnt idle also the self learning idle program from the power fc doesn`t work when the car is not idling i checked the throttle body and the valve for idle so the cams are not the issue... could it be that ligthten the crank flywheel is the problem...... i`m starting to geting clueless, ive got not much experience with modified engines (my first moded engine) so anyone a clue?? |
sounds like some sort of vacuum leak. Are you running a stock intercooler or aftermarket one? Check all the connections and make sure they arnt leaking air in.
Drunk posting FTW! ![]() |
the lines are fine, and i run a aftermarket intercooler but drove this one with my stock engine ago so it should be okay
anyway if there would be air leaking in, the car would rev up alone and that doesn`t happend if i go of the throttle it stall`s................maybe i`m wrong but i check for leaks, just in case, any other ideas?? |
#5 |
No more nissan.
![]() Join Date: Jan 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Sounds like your tune is crap for what you've built.
The vacuum lines may appear OK but do a pressure test on your IC piping.
