Old 11-28-2006, 03:09 AM   #1
wafi
wafi is an unknown quantity at this point
HELP!!! Weird noise when in reverse
There's a grinding noise heard from the rear end every once per tyre rotation .Moreover it feels like the rear brake is gripping when the noise is heard.The noise only can be heard when in reversing. Is it because there is a patch of rust somewhere on the rear bearing or other brake components?Coz my rear rotor seems fine n free of rust...Or is it my pads? from what i can saw my pads are new and still thick.
wafi is offline   Reply With Quote
Old 11-28-2006, 03:33 AM   #2
chmercer
chmercer's Avatar
siezed caliper? if you drive down the block or so, are any of the wheels noticabley hotter than the others? if so, that wheel has a sized caliper
or a dust sheild could have gotten bent and is contacting the rotor
or are your wheels all on tight? it will make a clunk noise if a wheel is on loose
just guessing
chmercer is offline   Reply With Quote
Old 11-28-2006, 04:10 AM   #3
wafi
yes,my wheels are all tight (i just had my alignment n wheel balancing done less than a mth ago) and i saw the guys tight all 4 up nicely...and i just bought 2nd hand rebuilt calipers for both rears last september...
Old 11-28-2006, 08:28 AM   #4
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Warped rotors?
If it was a seized caliper wouldn't the noise be constant?
HalveBlue is offline   Reply With Quote
Old 11-28-2006, 09:11 AM   #5
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
hmmmmmmmmmmmmm
what kind of diff ?
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 11-28-2006, 10:39 AM   #6
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
weird, my friend has this SAME problem. Exact same. It's weird, his brakes and rotors and calipers are fine. If it was a caliper, it would be constant. We are thinking bearings.
240silvia is offline   Reply With Quote
Old 11-28-2006, 10:56 AM   #7
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
check your pads and rotors in the rear, its usually the tell tale sign that its time to replace either of the two.
Slip Gypsies Blog
not sure if you realize this
Old 11-29-2006, 02:02 AM   #8
wafi
My pads and caliper are fine....but nt sure about my rotor though...how to check if my rotor are warped? btw the noise are worst when cold and it sometimes dissapear when hot or after journeys...i'm not sure about the diff,mine is an 89 model n should be an open one then...
Old 11-29-2006, 02:14 AM   #9
s13sr20detsilviastityper
s13sr20detsilviastityper's Avatar
s13sr20detsilviastityper is on the path to ruins13sr20detsilviastityper is on the path to ruins13sr20detsilviastityper is on the path to ruin
mine "grabs" as well every once in a while when reversing, i think its a caliper problem, the ebrake cable on taht side sometimes sticks, i need to take it apart and fix it
s13sr20detsilviastityper is offline   Reply With Quote
Old 11-29-2006, 09:48 PM   #10
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
i have the same problem...
at first i thought it was my diff...
but then i notice that if i brake or pull the ebrakes while on reverse ...it goes away
markyboi is offline   Reply With Quote
Old 12-05-2006, 06:51 PM   #11
brokens13
brokens13 is an unknown quantity at this point
the problem is most likely the caliper pins in the bridge, mine did the same thing and when i checked it out the pins wore out over time and were causing them to rattle or catch sometimes or sound like grinding but it would only do it in reverse, so i replaced the calipers and the noise went away
brokens13 is offline   Reply With Quote
