Old 12-06-2006, 01:27 PM   #1
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
My Power Steering is Posessed.
That's right, posessed.
This last week I got a hair up my ass and decided I was sick of not having power steering. Since I feel my arms have received enough of a workout from the powerless steering I decided to reinstall my power steering.
However...
Background: Back when I still had a KA my power steering worked perfectly fine, with not issues whatsoever. After I swapped in my S13 Blacktop I found a couple of leaks. Fixed those, and now my resvoir tank started overflowing, eventually loosing all the PS fluid. After refilling the PS resevoir 3 or 4 times I said, whatever, fuck it, and decided to drive without it (I kept the all the PS machinery like pump, belts, lines, etc. attached, just drove the car without fluid). That was about six months ago.
Issue: After filling up the PS system with fluid I tried bleeding the system via the instructions in the FSM. Everything seemed fine until I started the car.
HOLY SHIT! My steering wheel about broke my dainty little wrists.
Basically, as soon as I try moving the steering wheel either left or right, the steering wheel steers and counter-steers violently left and right. I mean, you litterally move the steering wheel .00000001 inches in either direction and it will move back and forth on its own something like 3-4 times a second. The wheels themselves rapidly move left and right about an inch or so.
So far I've done the following: replaced the PS steering pump with a known good PS pump; checked both hardlines near the cross member (all good); checked the PS resvoir; checked the lines that eminate from the PS resvoir; I even unhooked the PS sensor to see if it would make any difference, no luck. I unhooked the return PS line to see if the pump was circulating fluid and sure enough, all the PS fluid came pouring out.
I don't know what else to do. Anyone got any ideas on what's up?
HalveBlue is offline   Reply With Quote
Old 12-06-2006, 01:37 PM   #2
shuey_89240sx
shuey_89240sx's Avatar
shuey_89240sx is a well-known jackass
when you took your lines off did you blow through them? sounds to me lick you got somthing restricted and building up back pressure. and are you moving or sitting, when your steering wheel goes crazy?
'89 240 hatch
'89 240 hatch
1995 pontiac firebird LS1 trade for you 240 call for info. (217) 251-3054
painters get all the chicks
shuey_89240sx is offline   Reply With Quote
Old 12-06-2006, 02:21 PM   #3
HalveBlue
HalveBlue's Avatar
I checked all the lines for blockage. Nothing.
I've checked the wheel while sitting in the car, and while standing outside the car. Same thing happens both times.
I'll try to upload a video later on today to show everyone what's going on.
Old 12-06-2006, 03:52 PM   #4
shuey_89240sx
i've been checking all the tsb's i have at my access and even called my buddy who's a nissan master tech, he thinks it's a restriction too. but i can't any tsb's for any thing about the sr's power steering. but i got to thinking, i don't know if you have or not, but did you upsize the pully's, i know some people do, and that could cause pressure build up if their too big.
'89 240 hatch
'89 240 hatch
Old 12-06-2006, 04:07 PM   #5
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
if it's not a blocked line or a problem with your pump it pretty much leaves only one thing, your steering rack. It's possible that running it without oil for that long has damaged the internals. Might want to inspect/swap your rack... Crazy problem though, hope you get it sorted out.
edit: FYI of course unplugging the ps switch didn't fix it; that switch is used to send a signal to the ECU when it sees an increase in the line pressure when the car is at 0mph. The ecu when supplied with this signal increases the idle speed to compensate for the PS pump draw.
MELLO*SOS is offline   Reply With Quote
Old 12-06-2006, 05:13 PM   #6
HalveBlue
HalveBlue's Avatar
Here are two videos showing the situation
http://s94.photobucket.com/albums/l9...rent=PS002.flv
http://s94.photobucket.com/albums/l9...rent=PS001.flv
Let me know if they don't work.
I'll check again to see if anything is blocked.
And yeah, I had a feeling that pulling the PS sensor wouldn't do much. But hey, couldn't hurt, right?
Old 12-06-2006, 07:33 PM   #7
harlockssx
harlockssx will become famous soon enoughharlockssx will become famous soon enoughharlockssx will become famous soon enoughharlockssx will become famous soon enough
You've got your lines reversed somehow...same thing happened to my little brother when he swapped in his SR. Reverse the two hardlines on the bottom. HAHAHA!!! It finally happened to someone else!
Old School
harlockssx is offline   Reply With Quote
Old 12-06-2006, 07:41 PM   #8
yokotas13
yokotas13's Avatar
army FTW!!
That shit was hilarious!!!!
yokotas13 is offline   Reply With Quote
Old 12-06-2006, 07:53 PM   #9
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
hahaha that steering wheel was outrageous! that would definately crack some wrists
lexus baby
5t341tH is offline   Reply With Quote
Old 12-06-2006, 07:58 PM   #10
smelly240
smelly240's Avatar
i hate to laugh so hard but man - all i can say is "what kinda shit is that" hope its fixed now.
smelly240 is offline   Reply With Quote
Old 12-06-2006, 09:10 PM   #11
lexusisforlovers
lexusisforlovers is on a distinguished road
Send a message via AIM to lexusisforlovers
Uhhhhhhhhm that was absolutely ridiculous. I have problems with the SR power steering too. But nothing like that, mine just leaks
lexusisforlovers is offline   Reply With Quote
Old 12-06-2006, 09:43 PM   #12
nissanguy13
nissanguy13's Avatar
nissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant future
It should be a simple fix. Just take off the two metal lines under the engine and swap them. My friend recently replaced his clutch, and he took off his power steering lines when he dropped the tranny. My other friend put them back in the reverse order. When my friend started his car, it did the same thing and about broke his wrist.
Originally Posted by unicoladron;
dick, i had like 4 posi reps in a row and you ruined it
nissanguy13 is offline   Reply With Quote
Old 12-07-2006, 04:13 AM   #13
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
That video was fucking hilarous.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 12-07-2006, 04:25 AM   #14
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
ahaha That looks like a good thief procaution. Atleast if anyone tried to take your car (knock on wood) They would get another thing comming and hopefully they would have there hands in the smaller holes in the wheel and snap there wrist.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 12-07-2006, 06:52 AM   #15
samplesurf
samplesurf's Avatar
samplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to all
could also be a stuck valve in the pump or maybe missing some things inside there like the spring or a broken spring ive had my pumps do all kinda of weird things in the past when the valves and spring in it werent in the right place, try a new pump
samplesurf is offline   Reply With Quote
Old 12-07-2006, 08:45 AM   #16
sidewaysilly
sidewaysilly's Avatar
sidewaysilly is an unknown quantity at this point
Send a message via AIM to sidewaysilly
OH MAN! i thought i had the same problem until i saw that video....im still laughin...but yea, hope its fixed man!
SR20DEbT
sidewaysilly is offline   Reply With Quote
Old 12-07-2006, 11:22 AM   #17
cotbu
cotbu's Avatar
+ a Jillion,
That was some funny shit...Evertime I think about the that shit I crack up!(lady @ counter, thought I was laughing at her Moo Moo!!!)
Old 12-07-2006, 10:17 PM   #18
HalveBlue
HalveBlue's Avatar
Hooray for Zilvia!
My power steering now works thanks to you guys.
The PS hardlines were indeed reversed.
Old 12-13-2006, 05:13 PM   #19
harlockssx
Originally Posted by HalveBlue
Hooray for Zilvia!
Glad to have helped...
Old School
Old 12-13-2006, 07:02 PM   #20
smelly240
smelly240's Avatar
im still laughin my ass off at teh videos - a week and a half later.
Old 12-13-2006, 08:49 PM   #21
ms!3
lol your car is possesed. i dont what could be causeing that. i would guess you messed something up by running it dry with no fluid. im still laughing from that video.
ms!3 is offline   Reply With Quote
Old 12-14-2006, 08:43 PM   #22
ixfxi
Guest
Posts: n/a
fuck power steering. drain that rack and throw those parts in the fucking garbage.
Old 12-14-2006, 09:44 PM   #23
smelly240
smelly240's Avatar
we should make quick disconnects to switch em - so we can have some sick AntiTheft
Old 12-14-2006, 10:06 PM   #24
OWTKAST cpt
OWTKAST cpt is making a name for him/her selfOWTKAST cpt is making a name for him/her selfOWTKAST cpt is making a name for him/her self
Man... im on Dial up at the moment.. and i REALLLLY wanna see this.. owell tomorrow just wont come soon enough..
OWTKAST cpt is offline   Reply With Quote
Old 12-14-2006, 10:29 PM   #25
NismoGear5
NismoGear5 is an unknown quantity at this point
hahaha thank you for the vid : )
NismoGear5 is offline   Reply With Quote
Old 12-15-2006, 03:22 PM   #26
OWTKAST cpt
i giggled.... girl says "hehe thats rediculous."
