Old 12-10-2006, 02:34 PM   #1
silversr
silversr's Avatar
silversr is making a name for him/her selfsilversr is making a name for him/her selfsilversr is making a name for him/her self
Can't rev??
I just got done swapping in an sr20 in my 92 240, but there seems to be a problem, I cannot get it to rev,I can start it up fine but when I step on the gas it does nothing,so I went outside to turn the throttle by hand, but still nothing. I was thinking it was my z32 mafs but I don't think that would have an affect right?
silversr is offline   Reply With Quote
Old 12-10-2006, 02:39 PM   #2
Phlip
Yes, I look like that
Phlip's Avatar
Is the car properly setup to run that MAF, or did you just plug it in, close your eyes and hope it would work?
Any such situation, stock/modified, KA/SR, "can't rev" issues usually start at the MAF.
Weirdo
And I write too!
Old 12-10-2006, 02:39 PM   #3
TKfoshori
TKfoshori is a well-known jackass
Send a message via AIM to TKfoshori
my guess is maf also. it doesnt even rev a tiny bit?
For Sale
TKfoshori is offline   Reply With Quote
Old 12-10-2006, 03:03 PM   #4
silversr
silversr's Avatar
I got an Enthalpy tuned ecu to run z32 mafs and 740cc injectors.I'm using the stock z32 pigtail and matched it up to the sr's but the only thing I didn't do is ground the maf to the chasis,I heard it wasn't needed?
Old 12-11-2006, 03:05 AM   #5
Sileighty_85
Sileighty_85's Avatar
Sounds like you didnt plug in your TPS. Its not the MAF if it was your MAF the car would run shitty or most likely not run at all .
Old 12-11-2006, 10:06 AM   #6
silversr
silversr's Avatar
everything is plugged in as far as I can see, I was thinking it might be the tps but I have to wait and get a multimeter to check it out.
Old 12-11-2006, 11:49 AM   #7
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
I've driven my car with tps plugged and unplugged, didn't make a difference.
Check the tps if it's within spec and check the maf while you're at it.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline   Reply With Quote
