Help with SR20 and Defi setup
so i recently bought a 180sx from japan with the blacktop motor but im having some starting problems with it. Its getting gas and spark but its nt starting. it has e-manage so im not sure if that could be the problem as it may need resetting. Also i have a defi guage set and the oil pressure light comes on and the alarm will light up and it will beep. th oil seems to be fine and im wondering if this would cause it to not start up as the defi is linked to the cars itself?
going to slash the ecu codes today and try and diagnos it further but at this point has anyone else had problems with this sort of thing. Before it was the relay by the interior fuse panel that needed to be pluged in. It started fine after this then tried it again and it started and then died and i was unable to start it after that.
thanks for your help
chris
