Old 12-18-2006, 01:54 PM   #1
koukidrifter21
koukidrifter21's Avatar
koukidrifter21 can only hope to improve
SR sr power steering
ok guys i need some help here!!! i have a 1990 240 with an sr in it, but no power steering. i have the dohc pressure line and the hard lines and the reservoir. but on the sr pump there are two wholes were either the pressure line or the return line goes, i dont know wich one goes where, and i dont have a return line some one please give me a diagram setup or some pics of your own sr power steering setups thanks
koukidrifter
koukidrifter21 is offline   Reply With Quote
Old 12-18-2006, 02:03 PM   #2
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
SR Power Steering woes FTW!
The pressure line is connected to an elongated metal hose via a banjo bolt. That elongated hose, in turn, connects to the PS pump via another banjo bolt.
The suction pipe (curved, metal piece) connects the PS pump to the PS resevoir via a rubber hose.
Hopefully that made sense and helps.
Good Luck!
HalveBlue is offline   Reply With Quote
Old 12-18-2006, 02:42 PM   #3
koukidrifter21
but what about the other spot on the pump(the whole on the right)what goes in it?????????
Old 12-18-2006, 02:50 PM   #4
GR8WHITE
GR8WHITE is making his/her stupidity well-knownGR8WHITE is making his/her stupidity well-knownGR8WHITE is making his/her stupidity well-knownGR8WHITE is making his/her stupidity well-known
the hole on the top is where the high pressure hose connects with the large bolt with the two crush washers, and where the hole on the side is should have a curved metal tube attached to it by two bolts and that is the return line that should have a piece of hose attached to it with a hose clamp.
GR8WHITE is offline   Reply With Quote
Old 12-18-2006, 03:16 PM   #5
koukidrifter21
SR
now im really confused!! someone send me some pics of what ur talkin about
Old 12-18-2006, 04:39 PM   #6
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
here's an idea: why don't YOU post pics so that we know what YOU are talking about and perhaps help you out.
also the FSMs are readily available if you search.
