Old 12-18-2006, 02:09 PM   #1
jasonkg
jasonkg is an unknown quantity at this point
SR Running lean only in boost
My car is running lean as soon as I get into positive pressure. It starts sputtering and hesitating and the engine makes a knocking sound. I am able to attain 7 psi.
This started happening directly after I changed out the dump pipe gasket and I got a new intake filter (not the piping). I don't understand how this would give me a problem.
Here is the list of checks I have completed so far:
• Swapped out the mafs twice
• Inspected the intake tube for cracks
• Inspected all couplers for the intercooler
• Inpected fuel pump connector
• Did a FPR test
• Checked timing
• Changed spark plugs
• Inspected fuel lines
• Checked for vacuum leaks
• Swapped out ECU
• Checked turbo for shaft play (none)
• Checked BOV for leaks none (none)
I thought it was a boost leak at first, but it does not appear to be since I checked all parts that would be associated with this problem.
Is there something I missed other than engine internals. It seems like I am having a fuel pressure problem, or a sensor issue. Help please!
jasonkg is offline   Reply With Quote
Old 12-18-2006, 02:56 PM   #2
yokotas13
yokotas13's Avatar
how do you know you are lean?
Are you running a wideband or any datalogging setup?
yokotas13 is offline   Reply With Quote
Old 12-18-2006, 04:03 PM   #3
jasonkg
No I am not running a wideband, but if the engine is knocking that seems to be a sign that I am running lean. Is there anything else it could be?
As I stated this started happening right after I changed the intake. Before I got a new intake I had an old K&N intake. I used the filter charger on it. Is there any other problem excess K&N filter charger can cause other than a fouled mafs and would it contribute to my problem?
