Old 01-07-2007, 02:08 PM   #1
MarblewhtSR21
MarblewhtSR21's Avatar
MarblewhtSR21 is an unknown quantity at this point
s13 All of a sudden the car just died
I'm new to the forum so I checked first but I couldn't find anything that sounded like the problem I was having.
Car was driving fine earlier today. When I was leaving the shop the car started idling funny, like it wasn't running on all cylinders. But we checked the coil packs and spark plugs and did the wiggle test and looked for vacuum leaks and to no avail. And listened to the fuel pump to make sure it was sending fuel cause we thought the engine wasn't getting fuel or not enough and checked the relays for the pump itself.
Also a funny weazing sound from the intake so it could be the MAF but I just don't think so but I'll check tomorrow as it was too late and lack of light.
Any experienced opinions will help thanks.
MarblewhtSR21 is offline   Reply With Quote
Old 01-07-2007, 02:47 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Was there really a need to create 2 threads? No, there wasn't. The other thread has now been deleted.
Old 01-07-2007, 06:53 PM   #3
MarblewhtSR21
Wasn't aware there was 2 thanks??
Old 01-07-2007, 08:27 PM   #4
cmcdougle
cmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to behold
Send a message via MSN to cmcdougle
sounds like a vacuum leak, or a leaky gasket on the header or something.
cmcdougle is offline   Reply With Quote
Old 01-08-2007, 05:46 PM   #5
MarblewhtSR21
Yeah thats what we are thinking about the vacuum so that's something we'll check. But would a blown head gasket make the car sound like that or act like that.
Old 01-08-2007, 05:57 PM   #6
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Did you unplug the coil packs, one at a time as it was idling? If you unplug one and the idle doesn't change you have a dead plug/coil/etc. Other than, pull the codes to see what the ECU has to say for itself. I guess you probably have a broken sensor or bad wiring somewhere.
Also, what were you doing to the car at the shop before it started acting up? Were you installing parts or troubleshooting another issue?
MELLO*SOS is offline   Reply With Quote
Old 01-09-2007, 07:22 PM   #7
MarblewhtSR21
yeah that was the first thing I checked......and when I tried to do the Mode II diagnostics the red LED wouldn't blink. Further tinkering turned out that the eprom chip came off the mother board. Technically it shouldn't have even started but I guess she just wanted to run. Now I can go to the Tokyo Auto Salon this weekend.
Thanks for everyones professional help and opinions!
