Old 01-08-2007, 10:18 AM   #1
prang11
prang11's Avatar
prang11 will become famous soon enoughprang11 will become famous soon enoughprang11 will become famous soon enoughprang11 will become famous soon enough
Fast Flashing Blinker
This started happening about 2 days ago. My drivers side blinker flashes super fast while my passanger side flashes at normal speed. Possibly a loose ground? I changed the bulb and it didnt help.
I need to get this fixed so I dont look so ghetto when I obey the law.
prang11 is offline   Reply With Quote
Old 01-08-2007, 10:22 AM   #2
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
ok. your sure that all the turn sig. bulbs on the driver side are working?
hmmm maybe a relay problem, that or possibly ground issue.
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 01-08-2007, 10:24 AM   #3
LB.Motoring
LB.Motoring's Avatar
did you check both your front and rear turning indicators?
-__-
Robby Leuer
Old 01-08-2007, 10:25 AM   #4
zackt69
zackt69 is making a name for him/her selfzackt69 is making a name for him/her selfzackt69 is making a name for him/her self
check all the bulbs... front, back, sides - usually when it starts blinking fast a bulb is out or a connection is loose/unplugged.
zackt69 is offline   Reply With Quote
Old 01-08-2007, 11:07 AM   #5
prang11
prang11's Avatar
All the lights worked when I was parked. I didnt check my side marker lights. Figured those wouldnt have anythign to do with the blinkers. Guess ill be out in the rain tonight checking those as well. Hopefully one of thsoe is loose or something.
Thanks for answering my stupid questions
Old 01-08-2007, 11:11 AM   #6
jrmiller84
jrmiller84's Avatar
jrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond repute
Send a message via AIM to jrmiller84
I think I had this happen when I had the wrong bulb in one of my blinkers before, I could be wrong. If they're working but flashing oddly that could be it I suppose.
BitDestroyer.com
jrmiller84 is offline   Reply With Quote
Old 01-08-2007, 11:14 AM   #7
nissan90sileighty
nissan90sileighty is an unknown quantity at this point
try your flasher unit
nissan90sileighty is offline   Reply With Quote
Old 01-08-2007, 11:31 AM   #8
prang11
prang11's Avatar
flashers work normal
Old 01-08-2007, 12:24 PM   #9
zaneithan
zaneithan's Avatar
zaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to beholdzaneithan is a splendid one to behold
i had this happen when a wire came loose on my front blinker...check the connections themselves, hit the blinker on the side that is flashing fast and play with the connections
1993 240sx fastback (wrecked)
1991 240sx SE fastback Daily Driver status
1992 240sx fastback (???)
1986 Toyota Corolla SR5 Coupe (sold)
zaneithan is offline   Reply With Quote
Old 01-08-2007, 12:41 PM   #10
trsilvias13
Wrong bulb can make this happen as well.
trsilvias13 is offline   Reply With Quote
Old 01-08-2007, 12:53 PM   #11
koukimonster139
k. im gonna go ahead and tell you then, its not gonna be anything simple like a wrong bulb, or messed up wiring. Ill go back to my first idea, flasher unit/relay. I think there are 2 seperate relays, one for flashers, one for turn sigs.
ho ha ho chi chi
Old 01-08-2007, 12:54 PM   #12
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
Its because you have the wrong resistance in the circuit. Either a bulb is out or a loose wire or the wrong bulb. Anything that would change the resistence of the circuit.
Bryan Rogers
http://www.seriousbadass.com
brainfood is offline   Reply With Quote
Old 01-08-2007, 01:02 PM   #13
Gilboyto
Gilboyto is making a name for him/her selfGilboyto is making a name for him/her self
You may have a problem like mine did. I know mine was working normally when I first got it, and then randomly the right one would start to blink fast, and then it would go normal eventually, and then fast again.
My taillights at one point before I bought it had water in them, causing one of the bulb connections to rust. What I did was take off the connector, take some steel wool or something equivelant, and rub it down so the rust is gone. did the same to the bulb and that fixed the problem. Maybe you have rust in one of yours?
Gilboyto is offline   Reply With Quote
Old 01-08-2007, 03:56 PM   #14
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
Thats it, its an oscillator circuit and the frequency will change if the resistance changes.
Could be a bad bulb, corroded connection, bad wire, or the flasher unit or anything along the line. I haven't had that problem yet, but I'll bet one of those is most common on 240's (see who else has had the same problem, maybe a search will turn some up) and I'd start there before replacing all of the bulbs and relays and flashers.
Greg Fischer
[email protected]
'97 240SX SE
'98 Ford Explorer XLT
gfisch is offline   Reply With Quote
