Old 01-08-2007, 01:47 PM   #1
joeyz31
joeyz31 is an unknown quantity at this point
Wastegate Actuator
Does anyone know where I can find a wastegate actuator, for a T25, that is set for ~1bar?
joeyz31 is offline   Reply With Quote
Old 01-08-2007, 02:18 PM   #2
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
good luck with that 1 bar on a t25.
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 01-08-2007, 02:56 PM   #3
joeyz31
I read that a T25 can handle about 14 psi before it becomes inefficent. Did i read false information?
Old 01-08-2007, 03:03 PM   #4
koukimonster139
i wouldnt run 14psi on a t25 for more than like 5 minutes, and never again lol
ho ha ho chi chi
Old 01-08-2007, 03:04 PM   #5
johngriff
johngriff's Avatar
Buy some used actuators off the forum.
The start test cutting the arms, and welding/brazing them back together, i think about an 1inch and 1/4 off is 12psi IIRC.
Boost controllers dont work so well on internal gate.
[email protected]
Old 01-08-2007, 03:41 PM   #6
joeyz31
I dont really want to go with the boost controller. That is why im looking for a actuator that has a spring set fro ~1bar.
Old 01-08-2007, 03:49 PM   #7
mitdrx
mitdrx is a well-known jackass
I once thought the same. However a boost controller will keep that wastegate closed until it is party time. Plus you can get a JOE P controller for far cheaper than you could buy that actuator.
mitdrx is offline   Reply With Quote
Old 01-08-2007, 04:07 PM   #8
reactor
reactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nice
HKS sells an adjustable wastegate actuator. It's about $95.
reactor is offline   Reply With Quote
Old 01-08-2007, 07:30 PM   #9
joeyz31
anybody have a link to a site that has the HKS Wastegate?
Old 01-08-2007, 09:32 PM   #10
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
http://www.hksusa.com
Slip Gypsies Blog
not sure if you realize this
Old 01-08-2007, 09:45 PM   #11
reactor
www.phase2motortrend.com
Old 01-08-2007, 10:59 PM   #12
S14DB
AFC #1
S14DB's Avatar
http://www.atpturbo.com/Merchant2/me...egory_Code=WGT
Old 01-09-2007, 12:55 AM   #13
decksy
decksy is an unknown quantity at this point
nothign wrong with boosting t25 at 14psi as long as you have all the supporting mods for it...
gettin' it sidewayzzz
decksy is offline   Reply With Quote
Old 01-09-2007, 03:22 AM   #14
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
i had it set at 1 bar before with no buying anything. I changed the vacuum lines around. instead of it just coming off the throttle body it was t'd off into the intake tube. theres a nipple there already. i was making like 1.0-1.2 bar, until the engine gave out.
drifter808 is offline   Reply With Quote
Old 01-09-2007, 12:54 PM   #15
AuburnRyan
AuburnRyan is an unknown quantity at this point
I use the s13 HKS actuator and no Boost Contorller. You can adjust boost but screwing in/out the rod.
14 psi for 3 years no issues. Though I usually spool to about 5 PSI and change gears. Turbo has 0 shaft play and the motor is strong. 1
boost holds steady - rock solid. I've never used a MBC/EBC but I see no reason to with the HKS actuator working 100% effiectively.
'93 Fastback LE - Wrecked
'91 Fastback HICAS and LSD - Sold
'93 Fastback SE - Current
AuburnRyan is offline   Reply With Quote
Old 01-09-2007, 02:25 PM   #16
steve shadows
steve shadows's Avatar
thankyou, this is what I reccomend, either HKS or other adjustable arm
Its very simple you can adjust it on the car or before installing it to the turbo, you just pull the little c-clip off the arm attatchment to the wg door swing post and then pull it off the the side, losen the nut and shorten the arm.
The shorter the Int/WG arm the more boost you will get, because it will pull the door closer with more tension on the diaphram.
-steve
Like Me on FaceBook !
