Old 01-09-2007, 06:00 PM   #1
gotta240
GREASED front swaybar bushings...good or not?
I have a S.T. Front swaybar.. The mounts(ones to the chasis) are messed up.
I went to pepboys and found a set of Energy Suspension bushings/mounts but they have a grease fitting on them.... Should i use them and just not grease them, or should i just go ahead and grease them even though the stocks dont have a grease fitting?
thanks.
Old 01-09-2007, 07:41 PM   #2
projectRDM
projectRDM's Avatar
Think about that for a second. Why would they include a grease fitting if it wasn't meant to be used?
Stock bushings are rubber, they don't need grease. Urethane does or it will creak like hell.
Old 01-09-2007, 07:54 PM   #3
S14DB
AFC #1
S14DB's Avatar
They should have come with grease too. Just like the ST's did. If you didn't use the grease with the ST mounts. That is probably why they are messed up.
Old 01-09-2007, 08:44 PM   #4
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
Grease them. Done.
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 01-09-2007, 08:58 PM   #5
gotta240
I wasn't thinking about it...The st's were greased but didn't come with grease fittings.... These new ones are just better...
thanks and sorry for the dumb q....
