Old 01-09-2007, 09:22 PM   #1
LloydXmas
LloydXmas is just really niceLloydXmas is just really niceLloydXmas is just really niceLloydXmas is just really niceLloydXmas is just really niceLloydXmas is just really niceLloydXmas is just really niceLloydXmas is just really nice
super advans sa3r
I am looking to purchase a set of super advans. The ones i am looking at are 17x9 +22 offset. I have an s13 with apexi exv coilovers and I am doing the 5 lug w/z32 brakes. Will these clear the brakes, and how flush will these sit. Will i need to roll my quarters? Any help would be appreciated, thanks.
LloydXmas is offline   Reply With Quote
Old 01-10-2007, 10:10 AM   #2
S13 Charlie
S13 Charlie's Avatar
S13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura about
Send a message via AIM to S13 Charlie
Those wheels have spokes that should definitely clear bigger (Z32) brakes with room to spare. However, the offset might cause a clearance issue to your coilovers. You'd have to install them to double check, but it's going to be clooose. No worries though, a 5mm spacer would do the trick. Rolling your quarters depends on how low you go and what tire size you go with. If you go zilvia-approved low (aka slammed) with even 215/45 tires, then you'll need to roll. Now, with 215/45 and not too low, then you won't need to roll. I can't vouch for what's needed to fit wider tires (225, 235, etc.) but I think 215's are the only size that will fit without any kind of fender roll at all. Hope that helps..
-C
S13 Charlie is offline   Reply With Quote
Old 01-10-2007, 10:48 AM   #3
LloydXmas
thanks, that helps me out a lot.
Old 01-10-2007, 02:59 PM   #4
GSX Running
GSX Running is an unknown quantity at this point
they'll fit fine thats what I'm rolling on right now, will take pics of it and post them
GSX Running is offline   Reply With Quote
Old 01-10-2007, 09:13 PM   #5
LloydXmas
sweet thanks, it will give me an idea of what it will look like.
Old 01-10-2007, 09:21 PM   #6
GSX Running
there in my post of what do yall think
Old 01-20-2007, 09:52 AM   #7
LloydXmas
Well my wheels are on there way, and I won't be doing all the 5 lug stuff for about a month. I was wondering what clearance issues will i have with running 17x9 +22 up front with my car being low. I don't know what size tires i will be getting, whatever will keep me from doing body modification the most.
Old 01-21-2007, 08:21 PM   #8
LloydXmas
I guess no one has ran these up front of an s13? I just need some info from someone that knows how these wheels are and how hard they are going to be to put up front? Camber, tire size, will i need to pull my fenders or run spacers to clear the coils?
Old 01-21-2007, 08:49 PM   #9
OptionZero
OptionZero's Avatar
Is it that hard to look at one of the 1000xxx wheel threads and gauge how it'll fit?
up front might not clear coilovers and fitment depends on tire size and ride height
what the fuck is wrong with rolling fenders, you can do it with a baseball bat or a hammer yourself for free
OptionZero is offline   Reply With Quote
